eddiekranc
- Miami FL
Guessing it's a combination I'm in Miami FL lol even the 93 tune with just 93 ran the same
I hate the thought of wiring and hoses going back and forth. It's like 10lbs of S*** in a 5lb bag. Both would be awesome but I can't justify the cost for a daily beater.
I have the snow 210 kit and it was so easy and I converted the washer tank for storage. The install literally took 2 hours and looking back it could have been done in a hour if I knew what I was doing. But it does make a significant difference. I'm upset I waited so long to do it honestly.
Mounted to the frame right next to it.Ah wow, where is your pump? I still think an IC is more valuable than meth for me with the golf R IC now.
Ah ha and you are using the Snow kit with map voltage right?
Any chance you have dyno'd before and after or ran at the track to see if traps went up while spraying? I'm on the fence of grabbing a kit only because of the lack of performance I saw with race gas and how good the IAT's where with the IC. I've had meth on all my car (B6A4, B8S4, MKV GTi) but just bring down the IAT's should bump power.
You running stock ic?I have the snow 210 kit and it was so easy and I converted the washer tank for storage. The install literally took 2 hours and looking back it could have been done in a hour if I knew what I was doing. But it does make a significant difference. I'm upset I waited so long to do it honestly.
Sent from my XT1650 using Tapatalk
What boost tap are you running?
I haven't. Maybe next week. I was seeing 4-8 above ambient without the meth though so -5 is awesome to see. On a e30 blend right now I am running the 98 octane on the adjustable file. The meth is there just for a piece of mind honestly. Aquamist is suppose to be coming out with a port injection set up so I want to grab that when it's released.
Appreciate the feedback, thanks!
