Old 05-14-2019, 05:48 PM   #1
bobyjane1234
bobyjane1234's Avatar
Drives: MK7 GTI DSG
EPC light 15202 code
Howdy
Currently 47k km on my 2016 gti dsg. Has Uni stage 2 with dsg tune as well.
Last night did a couple of hard pulls in 3rd and seemed to be feeling good.
This morning I was on the highway in 5th at about 3000 rpm then EPC light came up, naturally limp mode ensued and adaptive cruise control was unavailable light came on.
Stoped on the side of the road, scanned it via BlueDriver and no code showed up.
Turned the car off and back on and there wasnít any lights on the dash. Conveniently I was headed to the shop and they scanned it and there was an unknown error p15202 (actuator module for turbo charger stuck).
Hopefully only solenoid issue and the thing isnít completely done for.
Went back home, as soon as I got to 3000 rpm the same situation happened.
I called shop and made an appointment and Unitronic said it has nothing to do with the tune and suggested not driving the vehicle but should be ok when shop appointment is due.
I did a bit a research and someone in the ED thread had this issue but he wasnít going in limp mode and some turbo failures on vortex.
Only mod that was done this year was an intake and changed the diverter valve to rev. D last week.
Anyone had this happen to them on similar mods, car, etc ? And what ended up happening ?
Thanks for the read!
VWR Springs, ST RSB, BFI Stage 1 engine + Transmission mount, HPA Dogbone mount, Rse10 + Pilot sport 4s. CTS Turbo Inlet, CTS Turbo muffler delete, CTS Intake, CTS Intercooler, Unitronic TBE, Unitronic S2 ECU/TCU
bobyjane1234 is offline   Reply With Quote
Old 05-14-2019, 05:50 PM   #2
JerseyDrew77
JerseyDrew77's Avatar
Drives: 2016 TR GTI S 6MT
Others can correct me if I'm wrong on this but it sounds like your wastegate is getting stuck.
Breaking V8 hearts and dreams - DBV2 Journal Bearing V2 Turbo w/TMD protuned by Ed (EQT) | CTS Intercooler (Direct Fit) | COBB Intake | MAP 3 inch Catless DP | AWE Track CBE | ECS & EQT Charge Pipes | BMS TIP | Spulen OCC | AEM 5 Bar w/APR Boost Tap | Bosch 4 Bar | NGK Racing Plugs (Heat Range 9) | Fluidampr | SuperPro Mounts | DKM Twin Disk Stage 3 Clutch | Autotech HPFP | PR Stage 3 LPFP | PR Fuel Line | Torqbyte PM4
JerseyDrew77 is offline   Reply With Quote
Old 05-14-2019, 07:08 PM   #3
Why?
Yes.
ED Moose E50 ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes / NT-05s on Asstins / Full Stealth Mode
Old 05-15-2019, 09:05 PM   #4
bobyjane1234
Drives: MK7 GTI DSG
Originally Posted by Diggs24 View Post
Why?
Yes.
The plastic outer rim was getting cracked and felt like it was staying open for longer than normal after shifting.
Rev d fixed that until this new issue surfaced.
Old 05-17-2019, 03:59 AM   #5
bobyjane1234
Drives: MK7 GTI DSG
Update: need new actuator, will be getting the CTS one. <<
Old 05-17-2019, 04:16 AM   #6
jimlloyd40
Drives: 2018 Golf GTI SE
How did you determine that?
jimlloyd40 is offline   Reply With Quote
Old 05-17-2019, 05:56 AM   #7
bobyjane1234
Drives: MK7 GTI DSG
I did not, the shop determined that on their end. I was told ;
Voltage at idile
Adaptation test
Flapper location on idile
Iíll know more tomorrow
