Golf MK7 - is my gearbox dying? 1st to 2nd gear crunch.
masrs
Scotland
Hi all,
I own a 2013 MK7 Golf 1.4 TSI with a 6 speed manual gearbox.
Occasionally (when the car is driven for sometime in a single journey), I start getting a crunch from 1st to 2nd. When it starts, it’s constant! If the car is switched off and cooled down, it seems to be fine again or if I drive it the next day.
Is my gearbox on the way out? Is there anything I can do to resolve?
Thanks
ColinStone
United Kingdom
MKVII 2016 Match BM
How many miles?
Sounds like the synchromesh 2nd to 3rd has been damaged. I had a crunch into 3rd gear when I damaged the synchro with a too fast a gear change without fully disengaging the clutch.
Don't think the gearbox will fail, mine lasted for a good few years and I sold the car with the crunch. But worth draining the oil and see how many metal shards and bits comes out. The drain plug may well have a magnetic debris trap. New oil may also help with it. Contrary to the book, it is worth changing the oil anyway.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Factory tends to underfill..well mine was...& the gear mech under the cabin is plastic & adds slop....which means bad gear shift..
masrs
Scotland
Thanks for the responses guys, it's on over 65k miles now! Should I be taking it to a garage to the gearbox oil change? What oil should I use?
ColinStone
United Kingdom
MKVII 2016 Match BM
Yes, I'd go for an oil change first and see if that improves it. It will also provide an opportunity to see if there is any debris. A VW independent specialist garage will know what oil to use or Haynes manual. At a guess an EP 80 or 90 oil.
And I meant possible damage to 1 to 2 synchromesh, not 2/3.
dr_mat
Berkshire
You may also have insufficient clutch release, which is always most evident on 1st to 2nd. If your clutch pedal is not consistent this may be a clutch cylinder issue.
...if it creaks, it's probably made by VAG
