FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Wheels / Tires / Suspension / Brakes / Chassis - Sponsored by The Tire Rack
The Tire Rack
Welcome to the Wheels and Tires section of GOLFMK7. This area is proudly sponsored by The Tire Rack.
If you are making a purchase from TireRack, please help support GOLFMK7 by clicking through to them with this link or clicking on the Tire Rack banner ad. Doing so helps give back to GOLFMK7 so we can keep this place running!
Reply
Thread Tools Display Modes
Old 01-14-2019, 02:11 AM   #1
ATR
Senior Member
Drives: 2017 Golf R 6mt
Golf R springs options
Looking for better handling with minimal drop (city streets suck).
I'm thinking between the VWR or 034 from the research I've done so far. Anyone have both of those setups?
Are there any other better options to consider?
ATR is offline   Reply With Quote
Old 01-14-2019, 03:31 AM   #2
ejones725
Member
Drives: 2015 GTI
Emmanuele Design or H&R OE sport springs are both supposed to offer a small drop, they say .75"
__________________
2015 GTI - Vorsteiner VFF 108 - Bilstein B16- H&R Front and Rear Sway Bars - 034 Engine Mounts - Superpro lower control arms and endlinks - Revo Dogbone - Tyrolsport Deadset - GFB DV+ - CTS Turbo Inlet pipe - BMC Air filter
ejones725 is offline   Reply With Quote
Old 04-17-2019, 03:11 AM   #3
ATR
Senior Member
went with 034's offering.
I like them so far. strangely enough they ride a bit better then stock yet at the same time the car doesn't lean into turns as much as before. best part? under steer is reduced. The R feels more pointed then it did before, yet at the same time still very planted.
Old 04-20-2019, 05:40 AM   #4
dv/dt
Junior Member
Drives: 2018 Golf R, 2006 Legacy GT
Thanks for the review! I've been contemplating this same question lately too. How are the springs on the city streets? Particularly with unexpected pot holes or raised bumps.
dv/dt is offline   Reply With Quote
Old 04-20-2019, 11:14 PM   #5
ATR
Senior Member
Quote:
Since I live and work around the Baltimore area that's a good question!
Anytime I cross into the city the car goes into comfort mode. It's ever so slightly more harsh. But it's still very livable!
The springs seemed to have brought the driving modes closer together. That is comfort seems to be close to how normal felt before. Normal is still my default setting for most of the driving I do.
Race mode feels like it should have felt from the factory. The biggest thing I didn't like about the race mode with stock springs is that it felt overdamped.
TLDR version...
Stock springs made the car feel underdamped in comfort. Just right in normal and overdamped in race mode.
The 034 springs seemed to have fixed that entirely. Every driving mode is much more usable than before.
Old 04-21-2019, 06:16 AM   #6
victorofhavoc
Senior Member
Drives: '16 GTI
FWIW I've got the 034 springs on my DCC GTI and I had MSS before. MSS is a milder drop and more comfortable. 034 is tough on some streets. Unexpected potholes have felt as if something on the car broke from the impact. Usually I don't find any physical evidence, but it doesn't feel great. However, on track in sport mode, it feels way better, and the stability under hard braking is greatly improved. I personally find comfort the only mode to be livable on the street. I use normal like sport. In sport, I find it to be super bouncy and it can affect traction. If I were commuting or just driving on the street, I'd choose the MSS. If you want stiffer, the 034.
victorofhavoc is offline   Reply With Quote
Old 04-22-2019, 02:45 AM   #7
dv/dt
Junior Member
thanks for the answers folks! I felt that the R is wayy underdamped in comfort mode too and normal still feels a little floaty still. Did my first AutoX in the R recently after a 12 years in a modified Legacy GT and felt slightly disappointed in Race mode, I actually switched back to Normal mode the second half of the day to get a little more grip. I'm glad to hear that the 034 springs may fix much of that without much loss in driveability! I'll keep an eye out for spring sales...
I looked at MSS springs too b/c they are also progressive, but they're like $700+ though?! I'd expect them to be leaps and bounds over the $350 034 for that price! Regardless, the 034 springs are different between the GTI and the R -along with a much milder drop- so I hope that slight difference makes up for the feel between the GTI and my R.
Old 04-22-2019, 03:07 PM   #8
victorofhavoc
Senior Member
Drives: '16 GTI
The MSS are expensive, yes. You get to corner balance though. They're not progressive, they're linear. The rear is a stack linear arrangement, and the shorter spring is mostly compressed with the weight of the car. The track pack is what I have. It's typically 1400$. I'm selling my kit with extras for 750$ right now. It's a lot more than the 034. At 1400$ and getting classed like you're on coilovers (if you race), it's a pointless option. The saving grace is the corner balancing and ride adjustment to get more rake. Looking back, I wouldn't do it again, but I also wouldn't get the 034 springs again. I'm ripping out the DCC, because it limits me too much. If you plan to keep DCC, the coilover options are slim, and the spring options promise a lot, but IME don't deliver as much as the stock suspension does.
Old 04-23-2019, 01:29 AM   #9
ATR
Senior Member
Quote:
You must have some really bad roads in your area for you to feel that way. I feel like the 034s are a good compromise spring for going a little lower then stock and also adding some much needed spring rate to the car. As I said above I feel like all the driving modes are much more usable then before where normal was my go to mode 90% of the time. Now I feel like all modes are much better then before. Even race mode feels better. Dare I say even a bit more comfortable?
If I upgrade to something else I would do the B16 Damptronic Coilover Kit (DCC compatible coil-overs) or the Ohlins road and track coil-overs (deleting the DCC in the process). But I simply couldn't justify the price of either kit right now because my car is mostly street driven.
Old 04-23-2019, 12:24 PM   #10
victorofhavoc
Senior Member
Drives: '16 GTI
We've got a lot of potholes in my area. The gti springs are also different from the r springs apparently. Even on smoother highway roads that have some undulations, the car feels oversprung in all modes, except comfort. I have the same issue with my 034 front springs that I had with my mqb205 mss; the spring is too short for the front strut, so at free hang the spring just rattles around. This makes noise against my metal top mounts going over potholes or curbs on track. Long term that wrecks the bearing and short term it contributes to a noisy and harsh ride. You won't hear it if you have rubber topmounts, but your bearing will feel it.
Old 04-24-2019, 02:51 AM   #11
ATR
Senior Member
It probably also helps that I am currently running 17" wheels and tires that are a carryover from winter.
I'm planing to change that over to 18's for summer though and will likely update my take on them.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
