FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 05-23-2018, 01:38 AM   #1
Jdreg
Senior Member
Drives: 2018 gti autobahn
Which oil spec
I’m seeing in VW oil charts that they have gas engine oil spec 502 through 509.
I getting a 2018 gti. Which spec should be used. Is the higher number an improvement over the lower and therefore can be used in its place.
Thanks
Jdreg is offline   Reply With Quote
Old 05-23-2018, 02:26 AM   #2
Joel
Senior Member
Joel's Avatar
Drives: 2017 GTI 6MT
502 spec is fine for the 2017 GTI.
Unless they updated your engine I would assume the same holds.
I run Motul 8100
__________________
Stratified, IE IC, MAP DP
Joel is offline   Reply With Quote
Old 05-23-2018, 02:34 AM   #3
Clem604
Senior Member
Drives: 2018 GTI
Quote:
Originally Posted by Jdreg View Post
Iím seeing in VW oil charts that they have gas engine oil spec 502 through 509.
Thanks
The 502 and 504 specs are approved for use in the GTI. I own a 2018 GTI and I use Motul 8100 X-Max.
__________________
MK7.5 GTI 6MT
JB1/Majesty IC/034 Upper+Lower Dogbone Mount/034 Eng+Trans Mounts/APR Pendulum Mount/034 Intake/APR TIP/Forge TMD/Remus Axleback/Neuspeed Short Shifter/42 DD Shifter Bushings/ECS Clutch Bleeder/ECS Clutch Line/WCT Pedal Spacer/DG Springs/EuroCode F/R Chassis Bars/Unibrace UBQ/H&R 24mm RSB/EBC Redstuff Pads/18x8 OZ Alleggerita
Clem604 is offline   Reply With Quote
Old 05-23-2018, 02:58 AM   #4
funks
Senior Member
Drives: 2018 Golf R DSG
Snag the Castrol Edge 0W40 A3/B4 Euro Formula from Walmart (less than 30$ for 5 quarts). It's a Class 4 Oil - PAO (unlike the other Class 3 synthetics) - and meets all the highest Euro Mfg requirements - including VW 502. Not sure why some people keep pushing Liqui Moly, twice as much and isn't officially tested at VW 502 (only recommended, not approved) specs unlike the two listed here.
API SN, API SM, API SL, API SJ, API CF, ACEA A3/B3, ACEA A3/B4
BMW Longlife-01
Meets Ford WSS-M2C937-A
MB-Approval 229.3/ 229.5
Porsche A40
VW 502 00/ 505 00
I believe Mobil-1 FS 0W40 meets the requirements as well (pretty sure the FS one is Type 4) but did lose it's BMW LongLife-01 spec (compared to Castrol).
API SN, SM, SL, SJ
ACEA A3/B3, A3/B4
MB-Approval 229.3
MB-Approval 229.5
VW 502 00/505 00
Porsche A40
Note: the small FS label near the handle.
funks is offline   Reply With Quote
Old 05-23-2018, 11:21 PM   #5
kcny
Junior Member
Hereís a list of approved oil for VAG. https://www.audiusa.com/content/dam/...-1.22.2018.pdf
kcny is offline   Reply With Quote
Old 05-24-2018, 07:57 PM   #6
dm33
Member
Drives: 2017 VW Golf Wolfsburg
Quote:
API SN, SM, SL, SJ
ACEA A3/B3, A3/B4
MB-Approval 229.3
MB-Approval 229.5
VW 502 00/505 00
Porsche A40
I'm attempting to research this at the moment. I looked up the SDS for Mobil 1 and its looking like group III. Wonder if they changed the formulation when they lost BMW LL01 certification.
The Mobil 1 SDS says: "Mobil 1 FS 0W-40"
Revision Date: 20 May 2016
Ingredients lists 40-70% "DISTILLATES, HEAVY, C18-50 - BRANCHED, CYCLIC AND LINEAR".
I'd say that makes it a group III. It does include 10-20% decene which is a PAO.
dm33 is offline   Reply With Quote
Old 05-24-2018, 09:05 PM   #7
Cameron1292
Senior Member
Cameron1292's Avatar
Drives: Mk7 GTI SE DSG Pure White
Anything approved by vw with their 502 will work fine. Cheaper options include the stated Castrol and mobile 1. I've always used mobile 1 0w40 on my mercedes. Used it for my first change on my mk7 then after tuning switched to liqui moly 5w40. Engine runs a few degrees cooler, and oil is cleaner when I change it. It is not only recommended for vw502 it is most definitely approved by vw themselves. A simple check on the bottle or website will show you. Same with motul, and a lot of other high quality oils. Don't over think it. Go with something approved for warranty reasons and your fine.
Sent from my ONEPLUS 5T using Tapatalk
__________________
Stratified Automotive Tuned---COBB intake filter---forge turbo intake pipe---VWR springs---RS7 plugs---MAPerformance catless downpipe---Custom turbo back with Magnaflow Magnapack---ECS Tuning Carbon fiber rear wing---19x8.5 Alzor 020 with General Super Steel 595 235/35/19
Cameron1292 is offline   Reply With Quote
Old 05-24-2018, 10:45 PM   #8
AspektZA
Senior Member
Drives: GTI Mk7 SE DSG
BMW is selecting 0w-20 for better fleet fuel economy ratings.
I'd suggest people get the SOPUS/Pennzoil Platinum Euro, as it's made with newer technology and has more stringent approvals.
AspektZA is offline   Reply With Quote
Old 05-25-2018, 03:02 AM   #9
20ls01
Senior Member
Drives: 2018 GTI SE 6spd
Im using m1 0w-40($10 for 5 quarts after rebates) when factory oil is changed. Don't need to overthink oil or spend big bucks. It won't make any difference as long as you use the oil with the proper approvals and weight.
__________________
2018 VW GTI SE 6spd, PW
Injen intake - Eibach 25mm RSB - KW Coilovers
Llumar 35% tint - 3m Scotchguard Pro PPF
20ls01 is offline   Reply With Quote
Old 07-12-2018, 07:56 PM   #10
MikeGmk7
Junior Member
Drives: 2016 GTI S
I never thought I'd be saying this, because after 40+ years of changing oil in my own motorcycles and cars I've never really "felt" a difference in how a vehicle performed with different oils, but I thought I'd pass along the following: Last two oil changes on my 2016 GTI, i used the Castrol 0w40. Seemed fine, engine sounded happy, etc. But I did notice some slight surging running up through 2nd and 3rd gears, and sometimes in 4th. I thought it was the stock mpg-oriented tuning or maybe my imagination, but.....I just changed the oil again, this time using 5W40 Castrol Professional from a kit offered by ECS Tuning. The hesitation/surging is GONE. Gone completely. The engine also sounds a bit sweeter at idle, less "clatter."
Anyone else have similar experience? I'm sticking with 5W40 until further notice.
MikeGmk7 is offline   Reply With Quote
Old 07-22-2018, 07:08 AM   #11
People909
Senior Member
Drives: 2016 GTI
Which is best to use, I think the manual says 5w40, but people are using 0w40. What is 0w40 and is it okay to use?
People909 is offline   Reply With Quote
Old 07-22-2018, 02:56 PM   #12
Cameron1292
Senior Member
Quote:
Just lighter weight when it's colder. As long as it's vw502 certified your fine.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
