Fantastic information guys.
When I first heard this noise ,pre bbk, I thought it was a WB and replaced it no more then 5k miles ago.
Could it be bad again... Maybe? but strange.
I will add that on the driver side if I push on the top of the wheel, and pull on the bottom of the wheel I get slight movement (pre and post BBK this has been there). This was also why I thought it was a wheel bearing when I first replaced it, however the movement was still there immediately after replacement.
So then one would think its the lower ball joint moving but everything looks fine and when I put a pry bar to any portion of the ball joint to make it move it does not and only flexes the steel control arm. I also videotaped it when I move wheel and it does not move. I can share if needed.
So then i started taking video of lower ball joint and coil over and found coil over moves slightly, I bought a new coil over kit and new one does the same thing so I am stumped again. Not sure if this movement is related or not, my guess is becoming not as like you had mentioned its a rotational noise based on speed.
like I said I have tried alot and completely stumped. I know CV will make noise when turning when failing but I have never heard of it doing this when stopping? Is that possible? And it wont make the noise in reverse?
