GranmasGotGame
- Ohio
INTRODUCTION
-To skip background info on me and go straight to the install skip to THINGS I DID
_____Yo. My name is Nate and I am a Bass Head. Back in December of 2015 I slammed my 2013 Hyundai Elantra into the rear end of a lifted Dodge 2500. I was going 45 mph and he was stopped so needless to say, I needed a new vehicle. Fast forward about 3 weeks and I find myself in this sexy little Golf TSI.
_____Now, it took me all of 2 seconds to realize, "Man, I really need my system back"; AND THUS THE NIGHTMARE OF INSTALLING AFTERMARKET AUDIO EQUIPMENT IN THIS PROBLEM INFESTED MACHINE BEGAN.
_____As I browsed the internet looking for information on how to install door speakers, how to install an aftermarket head unit, how to run a wire through the fire wall, etc. I quickly realized that not many people have posted about their aftermarket audio equipment on forums or The Tube of YOU. SO after all the heart ache I have gone through I figured I'd go about making something substantial for people to go off of. Hopefully they can learn from my mistakes/experiences with this car.
_____Having said that, LET'S MOVE ON TO THE FUN STUFF.
DISCLAIMER
I am a mediocre installer AT BEST, so methods and practices that I use in this guide could be sub-optimal or flat out wrong. I have about 4 years worth of on and off experience with aftermarket audio and have done a fair bit of research. I am not, however, anywhere near the level of a professional.
sorry to spoil the fun with that last paragraph but, figured I'd cover my ass before I post a "How to blow up your car guide"
that was a joke.
THINGS I DID
So, like the title says, these are all the things I did.
MATERIALS
that was a joke.
THINGS I DID
- Directly (I went in looking to do this)
- Added an aftermarket battery
- Added an aftermarket head unit
- Added aftermarket door speakers
- Added aftermarket sound deadening material
- Added a 4 channel amp for the door speakers
- Added 2 sub woofers
- Added a mono amp for subs
- Indirectly (I had to do this to accomplish the above)
-This is all the useful stuff. I did a bunch of other things but these are what people actually might find use out of.
- Tear and cut apart the dash (yeah, you have to cut sh*t off the inside of your dash)
- Pull out the trim on the bottom/sides of the car
- Remove the door panels
_____I'm going to categorize this as best as I can so bare with me here.
_____And I believe that's roughly everything; NOW, THE MOMENT WE'VE ALL BEEN WAITING FOR.
-Using a 13mm socket wrench, remove the screw along with the clamp that is holding the battery down
-The clamp will slide out by pushing up and towards the battery
-Remove the battery and prepare the replacement
-In my case I am using an XS Power D3400,
-Place the battery in the open tray making sure that the negative side is towards the cabin and the positive side is towards the front bumper
-If applicable, re clamp the battery down
-In my case, the battery is too large to fit with the clamp and fits snugly on its own so I don't re clamp it
-Attach terminal posts (if applicable)
-Reconnect terminal connectors as tighten
-DONE!
_____Now, I know what you're thinking. "Did this guy really just make a DIY for changing a battery? I was changing batteries while my mom was changing my diaper." Originally I was going to show the BIG 3 UPGRADE, along with switching out the stock alternator for a High Output one. Sadly, however, I am still figuring out where in gods name the engine block ground is and I have yet to decide if I even want to move forward with a HO alternator. Sooooooooooooooooooo, battery switch is all we get for now.
- After market head unit
- Need
- Aftermarket head unit (duh)
- Dash Kit
- Wiring Harness (expensive)
- Antenna Adapter and extender
- Golf Radio Unlock Keys
- Fuse Tap and 15/5 amp fuses
- 3(ish) feet of 18-16 GA wire
- Various tools for removing trim, cutting and stripping wire, screwing and unscrewing things that screw and unscrew.......yea just read below
- Electrical Tape
- Phillips Screw Driver
- Flat Head Screw Driver
- Plastic Removal Tool
- Wire Cutter/Stripper
- Box Cutter (sharp knife)
- Hot Knife (optional)
- PATIENCE (VERY IMPORTANT)
- Need
- Door Speaker Replacement
- Need
- Door Speakers (x4)
- 6.5"
- 6.5"
- Various Tools
- T30 "Star" Screw Driver
- 10mm wrench
- Thin/Small "precision" tool (could be small flat head or something else that's thin and sturdy)
- Shears
- Flat Backed/Thin Wire Cutter
- Electrical Tape
- Drill With Drill Bit
- Need
- Aftermarket Battery Installation
- Need
- Battery (yes I will do that every time )
- 13mm Socket Wrench (with extender)
- Need
- Sub Woofer / Amp Installation (this one's a little tricky cause everything is situational)
- Need
- Desired Sub(s) and Amp(s)
- Appropriate Wiring Kit(s)
- M7 Screw with Washer (debateable)
- Appropriate connections to head unit
- If aftermarket, you should be fine
- If stock, you need a line converter
- Need
INSTALLATION
Battery Removal & Replacement
_____I'm gonna start with the battery because it's quick and super simple
-Pop your hood and locate the battery
-Remove both clamps from the terminal posts using the appropriate socket wrench (I believe it was 10mm)
-There should be a crevice in the front of the battery, look down it and locate the screw that is holding the clamp on the battery.
-DONE!
Head Unit Removal / Installation
_____Now, I have had this head unit installed for a couple months now so I don't have all the pictures of pulling it out. I will do my best to explain everything so that it makes up for the lack of photos.
-Disconnect the positive or negative terminal from the battery (IMPORTANT) ~Because the car doesn't entirely turn off when the keys are out of the ignition [I blew a fuse the first time I tore apart the dash]
-Open the glove box
-Use your radio unlock keys to remove the radio from its housing in the glove box
-----to do this insert the radio keys making sure they are in the correct slot and simultaneously put them apart while pulling the radio towards you and away from the glove box. This will remove it from it's housing exposing the wires in the back
-Once you have disconnected all of the plugs from the back of the "mother" radio, release the keys from their slots and set the radio aside.
---To release the keys simply push in on the tabs on the side of the unit.
-Now move over to the center display
-Remove the trim from the climate controls panel
-To do this pull out (towards you) from the bottom, it should pop right out
-Once you have removed the climate controls trim it's time to remove the main trim
__________This is where I lack some photos because mine was done ahead of time
-Similarly to the climate controls trim start from the bottom of the main trim and work your way up
-Once you have released all the tabs underneath the vents, carefully use the bottom half of the trim (that you just freed from their clips) along with any point you can reliably grab and pull (that doesn't seem like it will snap) and pull it towards you
-This will pull the vents out of their holdings while the trim will stay attached to the vents (this is suppose to happen)
- Once the trim/vents are out look at the top and sides of the vent that were previously hidden
- There will be numerous small tabs that connect the trim to the vent, carefully disconnect these tabs and remove the trim from the vent.
***IMPORTANT***
-There will be a thin piece of trim that can come lose from main piece of trim, disconnect the thin piece and keep it, YOU WILL NEED IT FOR A LATER PART.
-Once the vent is out you have two options. You can disconnect the wire from the vent to move it out of the way. IF YOU DON'T PROPERLY RECONNECT THE VENTS BEFORE YOU RECONNECT THE BATTERY, YOU WILL CAUSE AN ERROR WITH YOUR AIRBAG SYSTEM. THIS ERROR CAN ONLY BE FIXED AT A VW DEALERSHIP OR WITH THE HELP OF A VCDS. [I f*cked this up pretty hard and still have yet to get it fixed]. The other option is to leave it connected and just work around it. (the safer method IMO)
_____Here is where the fun begins
-Once the trim is out use your unlock keys to remove the display portion of the radio from the dash
-Open the glove box
***IMPORTANT***
-Similar to the main unit in the glove box, the keys are released by pushing in on the tabs
-Quick video I just found for pulling out display trim
_____ https://www.youtube.com/watch?v=m_B8H0aEDhw _____
-Now a hot knife is highly recommended for this next portion
-There will be 2 plastic sections that need to be cut away in order to make room for the aftermarket head unit.
_____I have already cut mine so I don't have any images of what it looks like prior to being cut. So some super "high quality" photoshop work will have to suffice
-This first section can be cut with a box cutter as it is like a plastic foam hybrid material.
-The second piece CAN TECHNICALLY be cut with a box cutter but HOLY MOLY WAS THAT A PAIN. [I cut a piece of my pinky off while doing this with a box cutter and tore my knuckles up so I would not recommend]
-This piece is made of solid plastic so a hot knife would be optimal
-The shape in the photoshoped image is only a rough sketch of what it looks like, the red is where I cut the plastic so that its out of the way.
-This is what it should look like without the plastic (minus all the wires)
-Now that the plastic has been cut away we can work on feeding the wiring harness from plug where the glove box radio was into the display area.
-There are 2 ways that I know of to do this, one requires some bendable wire that you can use to feed it through, the other requires some clever positioning and a sh*t ton of patience.
_____I used the latter as it seemed the easier method of the 2.
-Moving the vents out of the way, there will be a hole in the bottom corner of the glove box side of the vent housing. You should be able to look through the hole into the housing for where the radio used to be.
-Make sure that the glove box is open and light is able to enter the former housing for the radio as you won't be able to view it otherwise.
-Feed the wiring harness through first, from there you can use it to feed any other wires you need to run from the glove box/radio housing (I.E. Antenna adapter, ipod/usb plugs, aux cord, etc.)
-From the center console it will look like this
-From the glove box it will look like this
-You will connect the wiring harness to the big black box thing, and the antenna adapter to the blue plug
-I don't have an image of the blue plug, but I do have one of the back of the radio, its gonna be the one that connects to far plug on the right (It's blue, that should tell you enough but yolo)
-Once all the wires have been ran, make all the necessary connections between the wiring harness and the head unit
-Now because the Golf wiring harness doesn't have a remote turn on wire, you are going to have to use a fuse tap to tap into a switched source.
_____I did some searching online and saw that people were able to use the fuse spot for the rear wiper to connect a radar detector so I did the same for the head unit
-I used a 15 and a 5 amp fuse (I think, can't quite remember) and ran the wire underneath the steering column towards the center console.
-If you use a flashlight and shine it into the driver side floor well (towards the center console) you will notice that you can see it through the opening in the dash.
-Run your wire up and into the dash opening and connect it to the remote turn on for your head unit.
-Once everything is connected, go ahead check to see if everything works
***IMPORTANT***
-DO NOT FORGET TO REATTACH THE PLUG INTO THE VENT BEFORE YOU RECONNECT THE BATTERY, OTHERWISE YOU WILL RECEIVE AN AIRBAG ERROR (if you disconnected it in the first place that is)
-If everything works, go ahead and start reassembling your dash.
-Attach the mounts onto the head unit and place it into the bracket (this all comes with the dash kit)
-Screw head unit into the bracket and reassemble the trim
*Remember to put the piece of trim that was save from before onto the new "aftermarket trim" there will be gaps otherwise
_________________________
There will be a picture here of the trim here when I get the picture
-The finished product should look something like this
Once again, will upload picture when I have it
_____That's about it for the head unit install, I will go into detail later on about hooking up/connecting a 4 channel to the head unit.
YOU TELL ME THIS AFTER I TYPE IT????????????
***IMPORTANT***
