idris
- Washington DC
- 2016 MK7
So I've been trying to remove the center console to get under to the 12v socket connector and I've seen a couple guides online on how to do it. The problem with these guides is that the manual handbrake and auto handbrake are different. As you can see the trim pieces are different which means not everything is the same down under. Has anyone had luck with removing the console with the manual handbrake? I just need access to the connector for the 12v socket so if I don't have to pull the whole thing off that would be a plus.
