funks
- Dublin, CA
What lug bolts are you guys using? I've got some Hypergrams coming in and Konig's site says that they recommend the spline drive tuner style conical bolts. I'm looking to run a 5mm spacer on the rear and want to use some 33mm shank length bolts. Will standard type lug bolts work? The "tuner" style bolt head looks to be a bit narrower than the standard bolts.
Thx.
ECS Tuning - for Black Wheel Bolts
28mm Shank Length Conical Wheel bolts
ES#: 2130049 Mfg#: B13-ZNNITT
- or -
30mm Shank Length Conical Wheel bolts
ECS#: 2130050 Mfg#: C17D30-ZNNIT
