BTD37
- United States
- 2019 Golf R
Is it my understanding that the app only works with AA before 3.0? If so, how do I downgrade?
adb shell pm install -i "com.android.vending" -r /sdcard/Download/Performance_Monitor.apk
Had a very succesful testdrive this morning.
Found some minor bugs:
- accelerator pedal/brake pressure text views not working yet
- G-force textviews are slightly too big when there's a negative G force
Should be an easy fix
Did you experience any issue/crashes with AA while performing your test?
Currently making a list of data elements that cause issues and making debug logs, so I can fix them. It's nice to be able to test the app on my own car now.
Temperatures cause sh*t. I'm currently rebuilding the way the code handles the temperature unit, F or C. The current way is not reliable.
There's hope for people that don't have any data showing up: this also happens when the app breaks on temperatures. The workaround is:
Go to the Android settings on your phone. Go to apps settings, find Performance Monitor, and click "erase data", so the app is back to "factory settings". After this, go into the Performance Monitor settings app, grant rights and select data which is not a temperature for the clocks. Don't use the 4 views yet, let's determine if there's data first. Let me know your results!
Can you also clean the storage for the VAG Extensions app?Followed these instruction of my U.S. GTI and still not receiving any data. Used 2.1 auto vex since 2.2 "Stopped working" everytime I launched the Performance monitor.
How do you get access to sensor data? Does/did Android Auto provide an API to do that?Hi all,
I'm building an app for use with Android Auto, that is capable of displaying car sensor data:
What exactly do you mean by that? I tested it this morning and started with a clean slate. I uninstalled VAG extension 2.2 and installed 2.1 so I am assuming the storage was already clean since it was a fresh install. Unless previous data is still stored? I also deleted and reinstalled the latest version of the performance monitor. I did not select any of the 4 text views. For the gauges I selected speed, RPM, and steering wheel angle. I also set all of these in the app before I connected my phone to my car and started AA. All of which was done on AA 2.9x
Cool Android Auto can talk to the headunit by the Exlap protocol. There's no official SDK for that, but someone took the Seat Drive app and reverse engineered an SDK.How do you get access to sensor data? Does/did Android Auto provide an API to do that?
FYI: I've written an iOS app that displays information obtained via OBD-II. I'd be interested to find any pointers to unique information that can be retrieved via OBDII on the mk7.
Only when using accelerator pedal/brake pedal position on a text view. When I was using other data, I could drive for more than an hour without any issues. No crashes, etc. But it's important the settings are not changed during an active driving session.
Thanks! The problem is with Android auto v3...Just tried loaded the app and it's no work. Love what you are doing. Help?
App appears to install. Android Auto doesn't see mobile device app or on car interface.
• should have full permissions
• Android Auto is in dev mode
• Android is still set to install unapproved apps.
• Android auto is version 3.0570554
• GTI software version
- device part# 3#0035844A
- hardware 710
- software 0751
adb push app.apk /sdcard/app.apk
adb shell pm install -i "com.android.vending" -r /sdcard/app.apk
I was hoping it wasn't the Android v3 issue I read about. Bummer. Hoping it'll work again in the future.Thanks! The problem is with Android auto v3...
There's a workaround, but it involves some manual action from a laptop or pc to your phone..
The following commands will sideload an app to your phone by using Android debug bridge. (adb). The com.android.vending is to tell the phone: this is installed by Google play store, which makes it visible in AA
Change paths and apk name according to your situation.Code:adb push app.apk /sdcard/app.apk adb shell pm install -i "com.android.vending" -r /sdcard/app.apk
