Mother
- Orlando, FL
ED emailed back yesterday asking for my VIN, which I sent them. Haven't heard back yet, but I will post up when I do. It would be pretty challenging to launch at the drag strip with the current behavior.
Eurodyne asked if I had any fault codes and confirmed RPM's should hold steady at 4k rpm. I told him no lights or anything, so I haven't checked for codes and I mentioned there are two more individuals in this thread experiencing the same behavior.
He said that he will try and get their 2018 test car back to see if he can recreate the issue.
Sorry, WOT post shift torque drop that occurs only in automatic mode. Doesn't happen when shifting manually with paddles or lever.
Getting the same issue. 7 Speed R and HO custom tuned. Any result in getting this rectified? Notice it more on a slight incline and changing into 5th. Cooler weather seems to have brought it on moreso.
No solution here.
So after going big turbo, it turns out the ED tcu tune does not increase clamping force.
The shop stated that without a TCU tune (a proper one), I cannot get rid of the boggy launch with my BOSS 600 kit.
The thing is this....The car does feel like its making the same torque down low so why would the tranny be my limiting factor and not boost build up and RPM?
They suggested I wait until UM comes out with there TCU tune in a few months.... At the moment, my car bogs on when using launch control (as if no boost is available)...
Eurocode and Pag parts are TVS Enginering dealers in the US. Their stage 3 DQ 381 tune holds up to 700 nm or 516 ft lbs.
Eurocode is getting me squared away. Thanks!
Do they need the car at their shop or can you flash it at home.
