Good morning all,
As the title says, I need you, I made several improvements in my car, Blinds Spot Detecion, Heated Seat, TPMS, Lane Assist (Module A5), so everything works perfectly, but a worry, my car once turned off and locked in my garage, if I do not use it for 3 or 4 days, when I come back, there is no battery, I have to open it manually, and then recharge the battery, which is quite annoying, it happened since I installed and plugs the Lane Assist, so I asked some who did the retrofit and I was plugged in the wrong places, I changed the location of the fuse but the problem continues. Can you help me? Or for example tell me what are the locations on golf 7 that uses power permanently even contact off?
Here is a picture of my installation with schema
thank you in advance
http://zupimages.net/viewer.php?id=19/42/0oge.jpg
