Quebster
- Dallas, Tx
Gotcha. Early '14 build here. No option to disable it but there is zero intervention with just setting ECS off [emoji1360]
Thx dude I'll give it a try!Pull green 40amp ABS fuse in the engine bay fuse box. The only way I can turn it off on my early 2015.
Sent from my SM-G935F using Tapatalk
Is the torque limiter removal and starting vibration reduction two different things?
No, they are the same thing. Even with ESC off, the car still cuts torque in first
Does the Clubsport come with ESC truly off mode or ESC Sport only?
Do you see a solid "ESC Off" icon on your instrument display when you hit the button?
Like so: https://www.youtube.com/watch?v=y_mkDoSMZ4Y
That's what we get in North America in a GTI when we do the VCDS coding to allow ESC Off instead of just ESC Sport.
How do I do this within the eurodyne diagnostic? I turned ECS off, but still feels like it's limiting
You can't turn off SVR with the ED cable. You need a VCDS or OBDEleven to do this
That's for ESC Off. He was asking about disabling starting vibration reduction
