FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 07-10-2018, 09:31 PM   #52
bluekid99
Senior Member
Drives: 2015 Volkswagen GTI
Quote:
Originally Posted by Luchos View Post
You're supposed to replace them as they are one time stretch to torque bolts. I did re-use one that had a stud on it because that's where my catch can bolts to. The replacement ones i got were all regular bolts..
do you remember the part numbers or anything for these bolts, i find like 3 different part numbers so unsure what to use
__________________
2015 GTI SE -IS38 APR, Unitronic IC, ECS Throttle and Outlet Pipes, RS7 Plugs, Turbosmart ECU BOV, CTS Intake, CTS Turbo Inlet Pipe, Niche Targa M129 18x8, VWR Springs, Unitronic Downpipe, Magnaflow CB, 034 Dogbone Mount, 034 RSB, Super Pro Endlinks, ECS Pendulum Mount, BoombaRacing Weighted Shift Knob, BoombaRacing Short Shifter, BMS Clutch Stop, SB Stage 3 Daily, 034 RSB, RS3 Coil Packs
bluekid99 is offline   Reply With Quote
Old 07-10-2018, 09:55 PM   #53
Luchos
Senior Member
Drives: Mk2 VW GTI Mk1 Audi 225TT Mk7 VW Golf R
Quote:
I may have the packaging hanging out in garage to check. There are two different sizes that bolt to frame and motor. The trans side might be different length too so it actually might be 3 different part numbers..
Edit: third part number is to secure trans mount bracket to transmission which does not require replacing because it shouldn't be broken loose during install
Luchos is offline   Reply With Quote
Old 07-10-2018, 10:01 PM   #54
Luchos
Senior Member
Did a little research
Engine side
N90596906 x 2 - Bolt M10x55
N10209605 x 2 - Bolt M12x1.5
Trans side
N90596906 x 4 - Bolt M10x55
N10209605 x 3 - Bolt M12x1.5
Old 07-10-2018, 10:10 PM   #55
tpellegr
Member
tpellegr's Avatar
Drives: 2016 GTI S (non-PP) 6MT
BFI lists (4) N-106-997-01,(3) N-105-524-04 for the trans mount hardware replacements.
https://store.blackforestindustries....mk7mqbprt.html
Those are the ones I bought. Am having it installed along w the engine mount next week.
__________________
2016 GTI S (non-PP) 6MT | Build Thread | APR Stage 1
tpellegr is offline   Reply With Quote
Old 07-10-2018, 11:50 PM   #56
ATR
Senior Member
Drives: Pure White 2017 GTI Sport 6mt
Most likely dried oil. Take it to the a stealership and replace main seal on warranty.
How would oil make it to the seal between the two halfs of the transmission?
The pictures show what is likely a silicone based sealant that wasn't properly cleaned up after install at the factory.
ATR is offline   Reply With Quote
Old 07-11-2018, 03:33 AM   #57
Luchos
Senior Member
Well first of that's not a very good/complete picture of the transmission. Secondly, when the main seal starts to fail it slowly starts to appear as a discoloration where the bellhousing mates to the block. That doesn't quite look like any adhesive to me, but maybe it is. I do know that when I had a seal failure on my car it resembled that picture.
Old 07-11-2018, 02:53 PM   #58
bluekid99
Senior Member
Engine side
Trans side
the funny part is that bfi shows different numbers entirely than what you have shown...this drives me to drink lmao
__________________
Old 07-11-2018, 03:13 PM   #59
Luchos
Senior Member
I went off the bolts CTS uses. It's the same thread pattern, 5mm variation in length between the two. A few drinks never hurt nobody, unless YOU street race of course.
Old 07-11-2018, 03:28 PM   #60
bluekid99
Senior Member
haha wellp went the bfi way since thats what im going with...lets see how this goes
__________________
Reply
Tags
034, engine mounts, mounts, racingline, superpro
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
