FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 11-13-2018, 07:22 PM   #69
Mk7GTl
Senior Member
Mk7GTl's Avatar
Drives: 2018 BMW 340i M-sport + Track Handling Package
The BFI transmission mount if by far the best since it utilizes the oem housing. I ran the full ECS engine and trans mount and my God the NVH was like a 93 civic swapped with a h22 engine equipped with innovative mounts. I kept the ECS engine mount and swapped the trans with the BFI stage 1 and NVH was cut down by 30% and more tolerable for everyday driving so i do believe the trans mount is the one that causes the most NVH.
__________________
IS38, Eurodyne Maestro tuned by Ghost Rider, Wagner IC, Cooling Mist water/meth kit, APR & CTS bolt-on's
2018 BMW 340i, M-sport + Track Handling Package, JB4, VRSF 4.5" catless + M-performance exhaust, BMS intake, BMS Meth Kit, 12.01@120.71 mph with 2.1 60'
Mk7GTl is offline   Reply With Quote
Old 11-13-2018, 07:48 PM   #70
PacDawg
Senior Member
Drives: 2016 GTI / 2008 Acura RDX
I've been holding on for the longest from upgrading my mounts because I dislike too much NVH. Was going to to with the 034/CTS style mounts but have seen those fail so will try just trans BFI stage 1 mount and hope that fixes most of my wheel hop issues without having to swap out the engine mount.
__________________
2016 GTI S DSG | 5150 IHX475 ECU & APR TCU Tune | ECS Intake | Unitronic Intercooler | Circuit Werks DP | VWR Exhaust | Precision Raceworks LPFP | Autotech HPFP | CTS TIP | Kosie K8R | VWR Springs | Llumar CTX 35% Tint
11.27 @ 122.33 mph IS38 5150
10.87 @ 128.03 mph IHX475 5150
PacDawg is offline   Reply With Quote
Old 11-13-2018, 08:42 PM   #71
Twist
Senior Member
Twist's Avatar
Drives: 2015 GTI SE 6MT - Unicorn Build Date :)
Quote:
Just my two cents PAC: don't change one of the three without doing the others. I did and it rekt my oem mounts even worse.
I think at the end of the day the little nuances with alignment , material used and design actually play a bigger role than people think. The oem design is the best for dd as it has a 360 degree rotational flex point. Where as my bfi stage one does not allow for as much smaller movement (I e noise).
You could just throw the insert into the trans and call it a day though. You just may wear your motor oem mount much quicker.
__________________
PM for Aluminum Heat Res. Air Scoops
PM for Obd11 Long Coding Help
Twist is offline   Reply With Quote
Old 11-13-2018, 11:54 PM   #72
predatorbird
Senior Member
predatorbird's Avatar
Drives: 2017 GTI Sport DSG
I agree with Twist. Think of all three mounts as a triangle. If you make one corner strong, it will make the other two corners that much weaker. I have BFI stage 1 eng/trans mounts and APR dogbone insert. I have zero vibrations, even with the AC on. I have additional engine noise, but I love it.
__________________
2017 GTI Sport DSG
Littco L450, EQT Tuned, APR TCU, HPA HPFP, APR Downpipe, APR Catback, IE Intercooler, Unitronic TIP, IE TMD, AFE Filter, ECS Silicone Inlet Hose, BFI Stage 1 Eng/Trans Mounts, APR Dogbone Insert, ED Springs, 19'' Pretorias, 10mm/15mm Spacers, P3 Multi-Gauge, S2T Paddles, Helix Sub
predatorbird is offline   Reply With Quote
Old 11-14-2018, 03:40 AM   #73
scrapin240
Senior Member
scrapin240's Avatar
Drives: '17 GTI Sport
I have the Superpro engine and transmission mounts (installed by a VW tech) and NVH is definitely increased on idle. Seems to be breaking in a little now after a few hundred miles, but still definitely noticeable from stock. At first it was like a tractor. I didn't do the dogbone yet, but that's going to be HPA.
Sent from mobile
scrapin240 is offline   Reply With Quote
Old 11-14-2018, 06:01 AM   #74
m3lonbr3ad
Senior Member
Drives: Alltrack
Quote:
Sent from mobile
Strange. I did just the engine and trans superpro mounts for about a month and my experience was little to no difference in nvh from oem. Then I installed the superpro torque arm bushing and again there was hardly any difference. I cannot say there is a definite increase in NVH, hardly perceivable. I'd need to sit a stock Mk7 to honestly determine if there was any increase.
__________________
2017 Alltrack: G-Pop rebuilt P&P IS20 | APR IS20 (91oct) ECU & TCU tune | APR intercooler | APR TIP | Golf R downpipe | Superpro eng/trans/subframe mounts | Superpro F/R sway bars and end links | APR pendulum mount | Konig Hypergram 17" | Continental DWS06 | Helix Sub
m3lonbr3ad is offline   Reply With Quote
Old 11-14-2018, 02:05 PM   #75
scrapin240
Senior Member
scrapin240's Avatar
Quote:
Hmm... Interesting.may have to look into it and anything is wrong
Sent from mobile
Old 11-14-2018, 08:09 PM   #76
Ridebjj
Senior Member
Drives: 2017 nbm gti sport
My NVH increased the slightest bit at idle from the mount combo (in my sig). I did them all at once and was half expecting to end up with some kind of tractor based on everything I'd read.
Nope. Throw in the vcds idle increase and It's close to zero nvh difference. Huge huge difference in performance though.
I know people shit on ECS here but I'm totally happy with their mounts.
__________________
Uni Stage1 | H&R OE Sport w/ Koni Yellow
Sigma Six SSK w/ SS line | BFI knob | Rennline pedals
HPA dogbone | ECS density mounts
Majesty IC | ST 25mm RSB
Flush spacers
Ridebjj is offline   Reply With Quote
Old 11-14-2018, 10:16 PM   #77
Twist
Senior Member
Twist's Avatar
Call me crazy. I think the reason some get nvh on certain mount products is INSTALL. It is much more complex than just "throwing it on" imho. There are very subtle alignment nuances
__________________
Old 11-14-2018, 11:22 PM   #78
Hoon
Senior Member
Hoon's Avatar
Drives: '17 GTI, Sequoia, Turbo Gixxer
Quote:
Agree.
I spent about 20 minutes with a couple of pry bars getting everything perfect for my trans mount
Hoon is offline   Reply With Quote
Old 11-15-2018, 12:03 AM   #79
SugarMouth
Senior Member
SugarMouth's Avatar
Drives: 2016 GTI Autobahn DSG PP LP
Yeah I made sure when I jacked the engine or tranny side that when I loosened the bolts the engine stayed in the exact position. This required multiple adjustments of the jack while releasing the bolts. This allowed me to swap the mounts once the old one was out in the exact same position. I have done the job twice now and both times it's good to go.
__________________
2016 GTI Autobahn DSG | FBO | Littco L450
SugarMouth is offline   Reply With Quote
Old 11-15-2018, 05:21 PM   #80
GolfWang
Senior Member
GolfWang's Avatar
Drives: '15 Night Blue DSG S
So, is there an install guide for this stuff? Or did any of you reference a DIY on vortex or something like that? I'm probably going to completely redo my entire mount suite (currently have 034 mounts + apr insert/pendulum, probably going BFI mounts + HPA puck/pendulum) in the next couple months, and i'd love to make sure that it's installed correctly
GolfWang is offline   Reply With Quote
Old 11-15-2018, 05:42 PM   #81
scrapin240
Senior Member
scrapin240's Avatar
Quote:
I think Twist's post above on the tranny mount is one of the most informative posts on this subject.
Also, ECS has a youtube video and instructions
Old 11-15-2018, 05:58 PM   #82
GolfWang
Senior Member
GolfWang's Avatar
When I first installed these. I didn't realize I put in the trans mount super askew. I think doing these right are a little more complicated than people realize. There are a lot of alignment nuances that I think most diyers miss when trying to do these at home.
That being said when I went to do it again the right way, I realized vw put a semi alignment circle I to the unused circle on the amount. This circle should sit in the exact middle of the mount. Mine was preloaded off to one side and caused some issues over time. Also, the engine mount block should be exactly 10mm from the frame with the mount perfectly parallel.
Yes. There is a lot of play in the design. It doesn't matter if they thread in clean, mine did and it was horribly off kilter and I could only tell when looking up at it with belly pan off. If you're down there you can look up and see if it's aligned with the frame.
Basically, imagine taking the trans mount when it's off the car and stretching it all the way to one side. That's how mine was after some miles. Pre loaded towards the firewall which caused some weird noises and a thudding sound when I free revved. VW built in an alignment circle (which no one online has mentioned). They're smart to do that. Basically the mount should be in the middle of itself, not stretched or askew, and then the trans should be aligned with that circle exactly in the middle both left to right and up to down.
I'd be willing to bet they even have a tool that is like a rod that sirs down in that hole and shows the precise alignment as it sticks out.
this stuff? also thanks didn't know about that. will certainly make sure the place i bring it to sees that before installing.
Old 11-15-2018, 06:08 PM   #83
scrapin240
Senior Member
scrapin240's Avatar
the post with the pic of the hole in the center for sure. as a pic is worth a thousand words.
Old 11-15-2018, 06:37 PM   #84
Twist
Senior Member
Twist's Avatar
The concept of install is simple (DAP videos, ECS, etc show procedure). The best advice I could give is to crack both mounts loose and do the trans first. Take a massive crowbar like Hoon mentioned and don't fully torque until that alignment circle is exactly in the middle of the mount without it preloaded off to one side. You could take an un-sharpened pencil to exaggerate the circle alignment and put it through both or just look straight down like I did.
Once those suckers are tight then do the engine mount bracket bolts back in, again making sure everything is straight and even (and a 10-11mm distance from bracket to frame).
Order of install:
Engine mount swap RAIL/Body only
Trans Mount Full swap
Engine mount Bracket Bolts
If doing dogbone do it last as it is kind of like a final lock on both.
__________________
Old 11-15-2018, 06:57 PM   #85
GolfWang
Senior Member
GolfWang's Avatar
wow. Thank you so much! really appreciated, a lot. will get back when I get around to redoing my mounts.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
