Old 11-09-2017, 03:51 PM   #18
Chillout
Drives: Volkswagen Golf MK7 GTE
Originally Posted by sprinks View Post
Crazy idea to get the collective geniuses thinking here: What's the situation on swapping the 7.5 display in with the mib2?
You can do it, but you need a high software version, like 1161.
Chillout is offline   Reply With Quote
Old 11-09-2017, 04:41 PM   #19
sprinks
Drives: GTI Mk7
Good to know. Just bought a mibII brain and was looking at this when i came across the 7.5 display. I guess it'll come down to what the brain software shows up as (i'm gonna guess older). I take it no easy way to update software on the mibII units still, correct?
P E T R O L P I N T S Enthusiast Inspired Pintglasses
wheelwell & GTI mk7 journal
Old 11-09-2017, 05:24 PM   #20
Chillout
Most of the updates are easy to do over SD-card.
Old 11-09-2017, 09:32 PM   #21
sprinks
Drives: GTI Mk7
But that SD is limited to VW dealer network, correct?
Old 11-09-2017, 10:17 PM   #22
Chillout
officially, yes
Old 11-10-2017, 10:39 PM   #23
sprinks
Drives: GTI Mk7
You coy dog you. All this scheming has me then toying with the idea of the bog standard 7.5 discover or the 7.5's discover pro.
http://st.automobilemag.com/uploads/...r-overview.jpg (linked because it's a huge picture).
Drool.
Old 12-09-2017, 06:07 AM   #24
sportwagen3
Anybody know where I can buy the app Connect activation code?
sportwagen3 is offline   Reply With Quote
Old 12-09-2017, 08:18 PM   #25
sprinks
Drives: GTI Mk7
Originally Posted by George Ab View Post
Parts:
VW Car Connect Activation Code: $240 shipped. http://www.allcarpartsfast.co.uk/vw-...830a-document/
or ebay
https://www.ebay.com/itm/Original-VW...gAAOSwDehZnoVS
Old 12-09-2017, 09:15 PM   #26
GolfWang
GolfWang's Avatar
Drives: '15 Night Blue DSG S
Does anyone know if I could just leave my MIB1 as-is, and replace the MDI connector with the MIB2's Aux/USB? I will probably do the full MIB2 retrofit in the next 2 years, but until then I cannot stand the lack of an aux cord.
GolfWang is offline   Reply With Quote
Old 12-09-2017, 09:57 PM   #27
danjam
danjam's Avatar
Drives: '15 GTI
USB/aux only works with the mib2
Sent from my Nexus 5X using Tapatalk
NCE MRMT: '15 GTI CSG SE PP LP 6MT
danjam is offline   Reply With Quote
Old 12-12-2017, 05:28 PM   #28
sprinks
Drives: GTI Mk7
I have finally got all my pieces for the swap. Guess that means maybe i'll be installing this weekend.
Old 12-23-2017, 01:42 PM   #29
ARi
Drives: Golf 7 GTD
What needs to be done to use mib1 amp on a mib2 unit
TIA
ARi is offline   Reply With Quote
Old 12-23-2017, 02:08 PM   #30
danjam
danjam's Avatar
Drives: '15 GTI
TIA
A lot. You can get a hacked mib1 to work with it. Otherwise you'll need to swap with an mib2 amp.
Old 12-23-2017, 09:15 PM   #31
ARi
Drives: Golf 7 GTD
Thanks for reply
Do you know where I can get a hacked unit in uk or delivered to uk
Old 01-03-2018, 08:43 PM   #32
sportwagen3
Any instructions on how to route the wire for the usb/aux? Did you remove panels on the passenger side or did you remove the glove box? If so, how did you do it?
Old 01-03-2018, 08:55 PM   #33
sprinks
Drives: GTI Mk7
I believe someone here has mentioned previously they basically used a thin stiff wire (think coat hanger straightened) to run the wire over to the glovebox area. That's the way i'll likely approach it as well.
Old 01-04-2018, 04:56 AM   #34
sportwagen3
I figured it out. Found that partially moving the glove box made it a lot easier to fish the wires.
