Hi everyone,
After reading this forum I decided to buy the "Dasaita 10.2 "Android 8.0 with Octa core 4 gb + 32 gb" for €341,- on AliExpress.
I've only had the pleasure to play with it for roughly 2 hours but this is what I've noted down so far:
- For installation I recommend watching and using the "Alpine X901D-G7 for Golf 7 installation" video on YouTube. Gives a perfect view on how to work the cables.
- having connected my OBD11, it won't give a 'scan' option, so the app is useless... I'm going to contact OBD soon.
- In my box there was already an "Dual Amplified antenna adapter", so no need to order one.
- I orderd the "Factory GPS Converter (FAKRA to SMA)" also via AliExpress, you can ask the retailer to make the cable as long as you want. Default is 15cm, I ordered a 1meter cable. Sellers name: LiiUoDo Official Store.
- The sound quality is amazing, way way better then my original MIB 1
There are 5 things which don't really work yet and I've requested help from the seller and received their response.
1: the 'steering wheel buttons' only show reset/save. I can't seem the program them the same as the movie in the above video.
Their response: no you can't change it, it works on CANBUS and should work fine...
2: the MFD does not show my phone is connected or current music I'm playing. I hope it's possible to get this connected, or I will be disappointed...
3: I connected once with my OBD11. A few days later, and having it removed from my car, if will still show this in my screen as connected. Not sure how to get rit of this.
Their response: change the name on devices.
4: Upon first installation I connected the Dasaita to my OnePlus's Hotspot. Now it will not allow me to connect to a different WiFi station. Which is very annoying.
Their response: delete current wifi station you use...
5: didn't ask this but I wasn't able to get "EasyCon" (which is AndroidCar?!) going. I'm hoping I need to use the other USB connector. I'm using the double one now, maybe I need to use the single one?!
More to come!!
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
