Old 07-14-2018, 11:10 PM   #14723
Haboob
Haboob's Avatar
Drives: '18 White Silver GTI Autobahn DSG
Nothing big, just ordered a Covercraft sunshade and a dual 2.4a charging outlet, since I left my other one in my Z when I traded it in.
Gonna disconnect the soundaktor later today and check out some other "tips and tricks" I've read with the car while I sit bored at home.
Haboob is offline   Reply With Quote
Old 07-14-2018, 11:13 PM   #14724
DubberMK7
DubberMK7's Avatar
Drives: 2016 GTI DSG APR Stage 1 + extras
Sounds way better with it off
DubberMK7 is offline   Reply With Quote
Old 07-14-2018, 11:55 PM   #14725
Haboob
Haboob's Avatar
Yeah, that's what I've read.
I can't believe it's an actual thing though... artificial sound. So dumb.
Old 07-15-2018, 12:13 AM   #14726
DubberMK7
DubberMK7's Avatar
Iíll admit that I didnít mind it for the longest time until I purchased the OBDeleven and turned it off. Maybe I was over thinking it was a muscle car
Old 07-15-2018, 01:03 AM   #14727
GoatPowder
Drives: GTI M6
Just get some poly mounts, the sound comes back... Except it's real.
GoatPowder is offline   Reply With Quote
Old 07-15-2018, 02:21 AM   #14728
JD-1
Drives: GTI
JD-1 is offline   Reply With Quote
Old 07-15-2018, 02:22 AM   #14729
Clem604
Drives: 2018 GTI
Originally Posted by JD-1 View Post
I removed mine too, clutch pedal feels much better.
MK7.5 GTI 6MT
JB1/Majesty IC/034 Upper+Lower Dogbone Mount/034 Eng+Trans Mounts/APR Pendulum Mount/034 Intake/APR TIP/Forge TMD/Remus Axleback/Neuspeed Short Shifter/42 DD Shifter Bushings/ECS Clutch Bleeder/ECS Clutch Line/WCT Pedal Spacer/DG Springs/EuroCode F/R Chassis Bars/Unibrace UBQ/H&R 24mm RSB/EBC Redstuff Pads/18x8 OZ Alleggerita
Clem604 is offline   Reply With Quote
Old 07-15-2018, 05:40 AM   #14730
Supermoto
Supermoto's Avatar
Drives: 2015 Mk7 GTI DSG SE
Ebay downpipe installed for total cost of $140. 100 for the pipe, 40 for various sealers, clamps, wraps, and spacers. Sounds absolutely amazing (exactly what I wanted this car to sound like), doesn't smell bad, and no check engine light. Those shifts sound amazing with a DSG
https://youtu.be/knMf3o91gRc
Tips for a perfect install:
- Install everything in the car and tighten all the clamps fully once fitment is found. Tack weld the slip joint together then get it properly welded by a shop.
- If the hangers are far off like mine, cut them clean off at the welds, grind the pipe smooth, then mount the pipe in the car and tighten everything. Place the hangers in the rubber mounts and see where they line up on the pipe (push the pipe up slightly to relieve the pressure off the rear hangers) then tack the hangers on. Remove pipe and get the hangers properly welded on. I made the mistake of trying to bend them and eventually the pipe cracked (even with heat). You will notice my rubber hanger mounts are being stretched a bit in weird angles. This is because I spent 2 days bending and heating the hangers instead of just cutting them and rewelding them. Do it right the first time.
Supermoto is offline   Reply With Quote
Old 07-15-2018, 06:00 AM   #14731
Your time is worth something. Why not just buy a pipe that fits first time?
Old 07-15-2018, 05:44 PM   #14732
southpawboston
southpawboston's Avatar
Drives: '17 GSW S
Finally installed my Helix sub. Nice upgrade to the stock system. Did the On-Top-Of-The-Spare placement with the extended spindle. Floor fits perfectly.
Bought a programming dongle, and will make it available to rent if anyone needs. PM me if interested (read the separate thread in Classifieds).
Thanks to forum member @dbwat for a spare Helix plaque so I could bling up my front speaker grilles.
OBDeleven coding mods
past VAGs: '69 Type 3 Variant ē 1984 GTI ē '85 Scirocco Wolfsburg Edition ē '86 Scirocco ē '86 Audi 4000S
southpawboston is offline   Reply With Quote
Old 07-15-2018, 06:46 PM   #14733
blaqsheep
blaqsheep's Avatar
Drives: MK7.5 GTI
Reading this killed me a little inside. Iíve had to get the car on jack stands like 6+ times to tinker with mine to get it right. Never again.
blaqsheep is offline   Reply With Quote
Old 07-15-2018, 09:29 PM   #14734
bobyjane1234
Drives: MK7 GTI DSG
Deauto Key, red foot-well lighting (LEDs). Looks great at night!
VWR Springs, ST RSB, BFI Stage 1 engine + Transmission mount, HPA Dogbone mount, Rse10 + Pilot sport 4s. CTS Turbo Inlet
bobyjane1234 is offline   Reply With Quote
Old 07-15-2018, 11:36 PM   #14735
Dubstro
Dubstro's Avatar
Drives: MK6 GTI (sold), Atlas, MK7 GTI
Finally got the Vibrant resonator installed (yesterday). Shop had to hack up a section of my AWE track and MAP DP to weld it on. Oh well, whole setup sounds great so no regrets. Shout out to GTIJake for suggesting Vibrants in his exhaust thread.
Funny story: While waiting for my resonator install. A guy with a hemi charger asked me how much HP a GTI has. He said he raced one and it "kept up" with him. I said my GTI was supposed to be 220hp stock. If only I could have captured the look on his face. Anyway, good job to that GTI, lol.
Today I swapped stock plugs for Brisk ER12S plugs. That was uneventful. Also, had a visitor (brother-in law) swing by with his new M2. Took it for a spin. Pretty awesome looking ride and handles amazing. Its hot as hell out so didn't try to do any WOT pull in his new car, haha.
2017 GTI Sport DSG - FBO+ / IS38 / ED Moose ECU / ED TCU
Dubstro is offline   Reply With Quote
Old 07-16-2018, 12:12 AM   #14736
Gogo GTI
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Sadly it also sounds like nothing with it off. My wifeís prius sounds as sporty as an oem GTI exhaust.
Gogo GTI is online now   Reply With Quote
Old 07-16-2018, 12:37 AM   #14737
DubberMK7
DubberMK7's Avatar
Haha Iím sure. But, being able to hear the turbo a little better is a plus Iím back and forth if I want a down pipe, I donít want people to hear me coming down the street. Been having an itch to do something...
Old 07-16-2018, 01:28 AM   #14738
Supermoto
Supermoto's Avatar
In the position I am in, paying 450+ for a downpipe for a quick install is far less worth spending 3 days installing a 140 dollar downpipe. I am on summer break with not much to do on my days off, so my time really isn't worth as much as the next guy. It was a very good learning experience and I would do it all over again the same way.
Old 07-16-2018, 02:04 PM   #14739
ubersick
Couldn't post it yesterday, but she got a wash
ubersick is offline   Reply With Quote
