Old 12-16-2016, 08:56 PM   #52
Mk72015
Drives: 2016 Golf R / DSG / DBV2 Hybrid
Originally Posted by 0bLiViOuS View Post
I'll probably pick up the BT Kit and use my old phone which supports MirrorLink so I have the gauges on my radio
I have a 2016 R, does that support mirror link?
Mk72015 is offline   Reply With Quote
Old 12-16-2016, 08:59 PM   #53
0bLiViOuS
Drives: 2016 GTI SE PP 6MT
The car does, but your phone needs to as well. Here's a partial list of phones with support, but you'll need to check with your phone manufacturer:
http://www.mirrorlink.com/phones
2016 GTI SE 6MT
IS38, ED Maestro, CTS DP, IE Intercooler, IE Closed Air Intake, CTS TIP, Neuspeed Charge Pipe/TMD
1995 Mitsubishi 3000GT VR4
1991 Honda's CRX HF
0bLiViOuS is offline   Reply With Quote
Old 12-17-2016, 12:20 AM   #54
George Smooth
George Smooth's Avatar
Drives: Golf 7 R
Let us know how it goes. I saw something about coding needed to keep it on once the car is moving.
Old 12-17-2016, 12:54 AM   #55
TwinDad
Drives: 2016 sportwagen
Originally Posted by Mydixadryl View Post
I almost went this route, but I figured I'd lose the ability to charge the phone. The BT dongle is outrageously priced, but I went ahead and got it anyway.
I have my iPhone plugged in as my main phone use a nexus 5 for the JB4 app. The iPhone will not work with the otg cable. It has to use the Bluetooth. I may invest in the adapter down the road. As far as charging with the otg cable, som phones have the capability to do so. The nexus does not unless I root it and change the kernel. That will probably be my next step. I used this cable.
https://www.amazon.com/gp/aw/d/B00CX...DSX7GFHMEQ9ZKE
Old 12-17-2016, 01:31 AM   #56
0bLiViOuS
Well looks like it'll work if I have OBDeleven... gotta find someone with one since I have VCDS lol
http://forums.mwerks.com/showthread....MIB2-working-(!!!)
2016 GTI SE 6MT
1991 Honda's CRX HF
Old 12-17-2016, 06:00 AM   #57
Perry01
Perry01's Avatar
Drives: 2016 GTI 4 DR DSG, 2008 TOUAREG V8
Ok Beta testers out there, my JB4 is going to be in tomorrow's (Saturday) mail and while I'm looking forward to the increase in power, I'm not looking forward to the multiple WOT runs where I live to fine tune the car. Can you guys provide some Map 6 (absolute) settings to give me a starting point? I know modifications and weather conditions will vary but I was hoping to get some input as to where to begin testing
It took me quite a while to get the JB1 to produce logs to my satisfaction. Does having more data to log and analyze make adjustments easier with the JB4?
2016 GTI - DSG | UR Downpipe | IE Intercooler | JB4 | 235/40 PSS | 034 Insert | Autotech CAI
VWR TIP | Leyo throttle and discharge pipes | 303 WHP |
Perry01 is offline   Reply With Quote
Old 12-17-2016, 06:35 AM   #58
0bLiViOuS
I'm just about to respond to your PM
2016 GTI SE 6MT
1991 Honda's CRX HF
Old 12-17-2016, 04:48 PM   #59
tylerf0606
tylerf0606's Avatar
Drives: 2015 Golf GTI S DSG w/ LP
My upgrade kit comes today. I'll probably leave it at map 2 since I don't think the roads will be in any condition for me to do data logging
Sent from my SM-G920F using Tapatalk
15' GTI S DSG LP
JB4 | IE Air Intake | CTS TIP | Eurocode TMD | IE Intercooler | BBE Turbo Back | H&R Coilovers | Powerflex Insert | Konig Rennform
17' Golf Alltrack S DSG
Eibach Springs | Neuspeed RSE12
tylerf0606 is offline   Reply With Quote
Old 12-17-2016, 05:01 PM   #60
RoidRage
Drives: Race Car
Wasn't MAP 2 for additives added on top only? Or am I mistaken?
RoidRage is offline   Reply With Quote
Old 12-17-2016, 05:27 PM   #61
themyst
Drives: '09 335i, '16 GTI S
Well, for one you have timing and fuel trimming data. Those are important.
themyst is offline   Reply With Quote
Old 12-17-2016, 07:49 PM   #62
"Map2: This map is a more aggressive map. Peak boost is set to 24psi with a taper down to 16psi at redline."
Old 12-17-2016, 08:26 PM   #63
RoidRage
Drives: Race Car
From George "Its additive based. 5.4 peak at the top."
That means needs to be combined wth ethanol blend no?
Old 12-17-2016, 08:52 PM   #64
I don't believe so. Check his first dyno:
http://www.golfmk7.com/forums/showthread.php?t=26382
"Map 2 yields 48whp and 60ft lbs on 91 on a stock car."
It's just an aggressive map.
Old 12-17-2016, 09:01 PM   #65
RoidRage
Drives: Race Car
Is map 2 adjustable at all like map 1 for JB1?
Getting quite a mixed message with map 2. But if someone used it with only 91 and stock....damn...
Old 12-17-2016, 09:09 PM   #66
m00se
Drives: 2015 GTI
By that he meant if the value shown in the software under map 2 was an additive pressure to the base map settings or if it was an absolute value. Nothing to do with fuel additives/ethanol.
m00se is offline   Reply With Quote
Old 12-17-2016, 09:11 PM   #67
geova05
Drives: VW GOLF R
No, JB1 is one thing and JB4 another. With that being said, the only map which allows adjustability is map6 on the JB4. George already explain all of this on a JB4 dedicated thread.
geova05 is offline   Reply With Quote
Old 12-17-2016, 09:14 PM   #68
RoidRage
Drives: Race Car
Ok thanks for clearing that up! Much appreciated .
