Old 07-14-2018, 08:55 AM   #5917
Denz.b
Drives: Mk7 gti clubsport
Originally Posted by Diggs24 View Post
I think the clubsport has that weird overboost function it does. Don't think one should run a JB4 with that. It will be either too low or too high. Can't tune for something that changes like that.
Valid point, tho and just guessing here but the overboost is activated by kickdown(rarely use it anyways) shouldn't that extra power which is controlled by the ecu requesting more boost be overriden by absolute numbers? I.e cancle the overboost completly?
Skickat frŚn min SM-G950F via Tapatalk
Denz.b is offline   Reply With Quote
Old 07-14-2018, 12:49 PM   #5918
Thumbs up
Originally Posted by bigdave79 View Post
So I installed an eBay twincooler a couple of days ago and have been playing around with some e85 on map 2. Here's my first log in 3rd. Timing looks good to me but I am no expert. I was impressed at the IATs which remained low until I took my foot of the gas. Let me know what you think!
Sent from my SM-G950U1 using Tapatalk
Lol. its map2 on ethanol. overkill. put some boost through that thing.
Old 07-14-2018, 12:57 PM   #5919
The ecu is always in play. you tune off of overboost and it might run lean when it isnt overboosting. you tune off no overboost it should be ok. so make sure you are tuning from no overboost runs.
pedal needs to be 100 for data to be relevant. 2nd run not sure what happened as ign1 wigged out. hopefully that doesnt happen often?
Old 07-14-2018, 03:02 PM   #5920
Denz.b
Roger! It's the first time I've seen ign1 do that, will run some more logs to verify it's not occuring regularly.
Other than that, would you need to see another log before I make any changes or do you have any suggestions of values?
Old 07-14-2018, 03:34 PM   #5921
bigdave79
Drives: VW GTI Mk7
What do you suggest?
bigdave79 is offline   Reply With Quote
Old 07-14-2018, 07:27 PM   #5922
symple84
Drives: GTI MK7
I am running Map 2 and I feel a slight hesitation when up around 5k RPM. It’s almost like the power cuts out for a moment. Would do some runs in Map6 help diagnose this problem?
symple84 is offline   Reply With Quote
Old 07-14-2018, 07:28 PM   #5923
railroader
railroader's Avatar
Drives: 2016 GTI Autobahn DP,Water/meth,turbo inlet pipe
Originally Posted by symple84 View Post
I am running Map 2 and I feel a slight hesitation when up around 5k RPM. Itís almost like the power cuts out for a moment. Would do some runs in Map6 help diagnose this problem?
Get a log of map2 and post it
2016 GTI Autobahn 6mt
EQT Vortex Turbo kit, lpfp walbro 450, Precision Raceworks MPI, DEI wrapped ceramic coated APR DP catless, turbo inlet pipe, 2 Nozzle Coolingmist water/meth, I.E. Intercooler,DKM Twin DIsk clutch, I.E full closed CAI, cts silicone intake hose, diesel geek sigma6, 034 solid bushing set, Spulen charge pipe,Custom Full 3" Hooker MaxFlow muffler
railroader is offline   Reply With Quote
Old 07-15-2018, 03:50 PM   #5924
mdpawlowski
Drives: 2015 VW GTI
Iím getting the same thing on mine.
mdpawlowski is offline   Reply With Quote
Old 07-15-2018, 05:36 PM   #5925
dood.
Drives: 2017 GTI S DSG
JB4 Logging, stacking and Map 6 Discussion
Still just running Map 1 on E25ish. Yesterday went for a drive in 90+ heat and Iím happy with how things are looking and that I can still push it when itís hot. The only thing that looks weird is the AFR and trims spike at the beginning of the 3rd gear log. Anyone know what causes that?
3rd Gear:
https://datazap.me/u/dood/7-14-18map...log=0&data=1-4
4th Gear:
Gonna try Map 2 soon.
2017 GTI S DSG | JB4 | ST Rear Sway Bar | Firestone Indy 500 225/40R18
dood. is offline   Reply With Quote
Old 07-15-2018, 08:42 PM   #5926
Spool spike is common with JB4. You can push more boost on E. Map2 isnt much more than map1.
Old 07-15-2018, 09:07 PM   #5927
dood.
So itís nothing to be concerned with? Yeah Iím thinking Iíll log Map 2 and then start an absolute Map 6.
Old 07-15-2018, 09:10 PM   #5928
Originally Posted by dood. View Post
So it’s nothing to be concerned with? Yeah I’m thinking I’ll log Map 2 and then start an absolute Map 6.
Nope.
Don't waste time on map2. Go to map 6.
1500 2
2000 3
2500 4
3000 4
3500 5
4000 5
4500 6
5000 6
5500 6
6000 6
6500 6
7000 5
Old 07-15-2018, 09:16 PM   #5929
dood.
Nope.
1500 2
2000 3
2500 4
3000 4
3500 5
4000 5
4500 6
5000 6
5500 6
6000 6
6500 6
7000 5
Alrighty Iíll give that a shot. Thanks for the tips
Old 07-15-2018, 10:35 PM   #5930
Crackness
Drives: 2016 GTI SE
Is a run from gears 2-5 be useful for anything? Or should it just be strictly 3rd and 4th 1.6k-6k rpm?
https://datazap.me/u/crackness/quick...75&tmax=310.63
Current settings are:
1500 0
2000 2
2500 3
3000 3
3500 3.5
4000 4
4500 4.5
5000 4.5
5500 4.5
6000 4.5
6500 4
7000 4
It was about 95-96 f ambient at the time of this run.
Shell 93 fuel, mods: IE CF intake (+"stage 2" pipe), turbo inlet, and Baun Performance FMIC. Stock clutch
Crackness is offline   Reply With Quote
Old 07-15-2018, 11:24 PM   #5931
1500 0
2000 2
2500 3
3000 3
3500 3.5
4000 4
4500 4.5
5000 4.5
5500 4.5
6000 4.5
6500 4
7000 4
It's ok, but ideally we want to see low rpm in 3rd or 4th to see what it is doing down low. Everything looks fine.
Old 07-16-2018, 01:45 PM   #5932
jibbajoe
Drives: MK7 GTI
Running map6 on ~E30 for the first time. I'm running my custom map6 i set in the spring during the cooler weather. Currently just testing it out in the hot weather with e30 blend.
Timing looks good but not sure how to read trims.
https://datazap.me/u/jibbajoe0129/ma...14-25-26-27-28
1500 2
2000 3
2500 3.5
3000 3.5
3500 4
4000 5
4500 6
5000 6.2
5500 6.2
6000 6.2
6500 6.2
7000 5.3
jibbajoe is offline   Reply With Quote
Old 07-16-2018, 01:50 PM   #5933
1500 2
2000 3
2500 3.5
3000 3.5
3500 4
4000 5
4500 6
5000 6.2
5500 6.2
6000 6.2
6500 6.2
7000 5.3
Looks good.
