FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 06-12-2019, 12:15 AM   #1106
GeorgeTSI
Member
Drives: Golf TSI MK7
Quote:
Originally Posted by mk7_bk
Any ideas when this is getting back on the market, couldnt find any on ebay.
You said these are probably the same thing lol
https://www.ebay.com/itm/273339153428/
https://www.ebay.com/itm/273339153313/
https://www.ebay.com/itm/222608356740/
https://www.ebay.com/itm/322652215411/
GeorgeTSI is offline   Reply With Quote
Old 06-12-2019, 01:23 AM   #1107
mk7_bk
Senior Member
mk7_bk's Avatar
Drives: 2017 GTI S 6speed
Ah so p&x is the new magic huh
__________________
TODO list: Stop spending money
mk7_bk is online now   Reply With Quote
Old 06-12-2019, 01:38 AM   #1108
OBP
Senior Member
Drives: 2016 Golf R
Quote:
Originally Posted by Sumfuncomet View Post
As far as my mods go I tend to stick with products that are well engineered and dont require trimming or fussing to get it to fit. When the Chinese buy a Wagner intercooler and reverse engineer it, you are buying a copy, a copy that may look the same but not perform the same. I bought an IE intercooler because I like the engineering that went into the directional vanes located inside the intercooler and the careful measured performance of IAT. Do the chinese do engineering studies like that? Would you fly on a Chinese copy of a Cessna or the real thing??
Quote:
Originally Posted by wy2sl0 View Post
I just went 10.78 on my China stock mount.
Gordon went 10.4 on his.
I think for $300 it is unbeatable.
This was taken from another thread, but just think, if hed have used a REAL intercooler like IE or APR, those runs would have definitely been 9 sec runs!
OBP is offline   Reply With Quote
Old 06-12-2019, 03:02 AM   #1109
GeorgeTSI
Member
Quote:
I don't know, that's what I was asking I can tell you the pictures are exactly the same as the CSK ads, identical, just a bit enlarged and the logo differs. People here have bought from both sellers (hisinauto2015 and au2parts2015) and I haven't seen any complaints, so it looks like it...
Old 06-12-2019, 03:32 AM   #1110
Stija
Senior Member
Drives: Wrx
Quote:
Yes im sure IC is the reason for those times, just like Im sure everyone cares about 1/4mi times.
You missed the point of his post somewhat... by a quarter mile Id say.
Stija is offline   Reply With Quote
Old 06-12-2019, 03:36 AM   #1111
KyACRASH
Senior Member
Drives: 2015 GTI
I think (hope) he was being sarcastic.
KyACRASH is offline   Reply With Quote
Old 06-12-2019, 02:02 PM   #1112
Stija
Senior Member
Drives: Wrx
He was sarcastic in re: 9s and IE and APR.
Old 06-12-2019, 02:24 PM   #1113
arob157
Senior Member
Drives: 2017 VW GTI SE DSG
Quote:
Originally Posted by AlienSP View Post
That's alright, my radiator tabs on my IE slip out too.
Well damn. I am thinking about using a shiny and adhesive such as RTV to "wedge" the rad clips in place. My radiator actually contacted both the AC hose and my throttle body connector.
The contact actually cracked the connector housing. Gotta figure out if I can get the connector replaced. Still functions fine though.
__________________
ED Stage 2 e50 ECU & Stage 1 DSG // Stock Intake Mods // Autotech Intake // Unitronic TIP // Magic IC // IE Downpipe // BFI Stage 1 Engine & Trans Mounts // EuroCode RSB // Moog K750809 Endlinks
arob157 is offline   Reply With Quote
Old 06-15-2019, 08:29 PM   #1114
arob157
Senior Member
So I decided to try JB Plastic Weld. It is a "low-psi hold" filler/epoxy that is a 2-part putty that is activated as you combine the layers. I placed some underneath the radiator clips and on both sides of the clips to fill the voids (hoping that the rad clips wouldn't be able to compress when large bumps are hit allowing the rad to move back). I also filled the area next to the large alignment tabs on the radiator below the clips.
Will keep the thread updated if this functioned well or failed.
__________________
Old 06-15-2019, 09:46 PM   #1115
George Ab
Senior Member
Drives: GTI MK7, BMW E90
It has been a year and a half since I installed this intercooler. Nice to have with the weather starting to warm up. Thanks again to OldschoolMK7 for doing the initial leg work and write up.
George Ab is offline   Reply With Quote
Old 06-17-2019, 12:21 AM   #1116
SDZ007
Junior Member
Drives: audi s3 8v
guys, what tool are you using to file down the pegs? and is it only the one side that need a filing?
SDZ007 is offline   Reply With Quote
Old 06-17-2019, 12:23 AM   #1117
KyACRASH
Senior Member
Drives: 2015 GTI
Quote:
Fitment of this thing is inconsistent, you'll have to measure and decide for yourself.
I got lucky and didn't have to file down either side, but it seems most have had to file at least the driver's side. If I had to file I would have used an angle grinder.
Old 06-17-2019, 12:50 AM   #1118
JCAT
Junior Member
Drives: 2017 Alltrack
I had to file down both sides substantially. If I knew ahead of time how much it was going to need removed I would have gotten my Dremel out. Unfortunately, because I didn't bother to measure it first I just ended up working it by hand with a bastard file until it fit.
JCAT is offline   Reply With Quote
Old 06-17-2019, 03:40 AM   #1119
SDZ007
Junior Member
Drives: audi s3 8v
currently my pegs measure 29mm on each side.. but this is going into an s3 so not sure if it's different.. if I can prep it before it goes on that would be ideal.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
