Cuzoe
- Los Angeles
I've read a lot of forum posts, but it seems that USB harness replacement is only needed for cars that had MDI rather than USB. Also as stated in my post, 2 MIB2 would have USB working properly (showing as source of media and working with android auto) BEFORE removal of component protection and adaptation. So it's really not the usb port...
If App Connect is okay with your good MIB II do you need Media in? I don't know if there is a separate FEC for it but I'm pretty sure when you start at connect it says your device cannot be used as a Media source at the same time.
Sent from my A0001 using Tapatalk
Hmmm, As I'm submitting that post it occurs to me that maybe you are connecting another USB device for media that isn't a phone, in which case I could see it being a problem.
The biggest problem I have, which might be due to having an older less efficient phone (OnePlus One), is that my phone is using battery faster than it charges with app-connect running. I thought I would be able to get rid of my 12 volt charger but if I get in the car with a low battery I have to use it and listen to audio through Bluetooth until it charges. I lose 2 to 3% battery in my 30 minute commute. Plugged into the charger but with navigation running, screen on, I would gain 10% battery in that same time, although the phone would be burning hot if I didn't have it mounted right in front of the A/C vent.
Back on topic: outside of your phone what do you use as a Media source?
