I have been using the Webasto just to warm up the car, say 20 minutes before departure. it's awesome, it's one of those option I am so gonna get used to, will be compulsory in any car I will buy after the Golf.
as I said, up to 3 timed events can be programmed under the climate screen. basically you choose heating or ventilation, and set the target temperature in the Climatronic when leaving the car. based on the outside/inside temperature, the heater will decide when to start. so I choose heating for 7.40 in the morning, and ventilation for 16.15 in the afternoon (the car stays under the sun all day).
the remote just starts the machine, heating or ventilation must be decided earlier. then it runs for a set amount of time.
apparently when it's really cold outside, the engine can decide to use the heater even if not programmed. we'll see, it's not winter yet.
everytime the heater starts I still gets one or two faults logged, and I am currently investigating but nothing appears to be wrong.
one fault says FUEL TRANSFER PUMP NOT ACTIVATED, and it relates to the main fuel pump for the engine. I don't understand, as the heater has it's own dedicated pump. this fault will come up everytime the heater starts, no matter what.
another fault says NO FLAME DETECTED, I believe the fuel line is not the right size and the fuel delivery is below what the heater needs. this fault comes up most of the times but not always.
overall I am beyond satisfied, and happy that I did 95% of the retrofit by myself.
