FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 08-11-2019, 04:35 PM   #18
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Quote:
Originally Posted by JerseyDrew77 View Post
Like it really makes that much of a difference?
Removing 30 lbs without effort or drivability or any other sacrifice seems ok to me. Im going to take out my spare + fender and put in a custom small box and 10Ē sub. More bump and less weight there too. win win. well except my wallet.
__________________
ED Moose E50 ECU tune / ED DSG Stage 2 tune / Tomioka IHX475 Turbo / IE IC / MAP cat+res DP / Autotech HPFP / PR 450 LPFP / Uni TIP / EQT TMD and Pipes / NT-05s on Asstins / Full Stealth Mode
Diggs24 is offline   Reply With Quote
Old 08-11-2019, 04:39 PM   #19
JerseyDrew77
Senior Member
JerseyDrew77's Avatar
Drives: 2016 TR GTI S 6MT
Quote:
Originally Posted by Dragk913 View Post
Itís a 30ish pound weight reduction. Itís not a giant difference, but when combined with removing the rear seats, lightweight wheels, lightweight BBK, lightweight racing seats up front, etc. it helps. Just how much? I canít say, but the internet is full of calculations for weight reduction to quarter mile trap increases.
Shit, at that rate, mine as well just gut the whole inside and just leave the driver seat and replace the whole exterior with carbon fiber.
__________________
Breaking V8 hearts and dreams - DBV2 Journal Bearing V2 Turbo w/TMD protuned by Ed (EQT) | CTS Intercooler (Direct Fit) | COBB Intake | MAP 3 inch Catless DP | AWE Track CBE | ECS & EQT Charge Pipes | BMS TIP | Turbosmart DV | Spulen OCC | AEM 5 Bar w/APR Boost Tap | Bosch 4 Bar | NGK Racing Plugs (Heat Range 9) | Fluidampr | SuperPro Mounts | DKM Twin Disk Stage 3 Clutch | Autotech HPFP | PR Stage 3 LPFP | PR Fuel Line | Torqbyte PM4
JerseyDrew77 is offline   Reply With Quote
Old 08-11-2019, 04:43 PM   #20
Diggs24
Senior Member
Diggs24's Avatar
lol. gotta retain the stock look. still got my boat anchor austins. also someone rides back there.
__________________
Old 08-11-2019, 11:46 PM   #21
BosGolfR
Junior Member
Drives: MK7 Golf R
https://meledesignfirm.com/collectio...-battery-mount
Posted this in the other forum as well. No experience yet, but the cage is well made.
BosGolfR is offline   Reply With Quote
Old 08-17-2019, 08:53 PM   #22
Diggs24
Senior Member
Diggs24's Avatar
Correctomundo! VCDS or OBDEleven.
Also, I followed TecklenburgVW’s first post of that thread for coding, not Mursepaolo’s on the second page. The only thing I did differently is coding the Battery adaptation-Rated battery capacity Adapted; Teck used 39ah (stating that was the lowest that the system would recognize), however I was able to successfully set the capacity to 13ah (which the Braille G30 is) AFTER changing the battery type to Lithium Ion.
Thanks. So I did 39, no problem.
THen moved to lithium ion. no problem.
Go to change it from JBA to Braille and fails "out of range"
Braille, BRA, Braille Battery. None work.
Went to serial and that didn't work. Out of range. Maybe it needs to be same # of digits and I need to add zeros out front?
I know my vcds is out of date so will download newest but not sure why that would matter. Will go back in and try 13ah too.
Does battery MFG and and serial # really matter?
__________________
Old 08-17-2019, 09:24 PM   #23
Diggs24
Senior Member
Diggs24's Avatar
Success.
Updated vcds
Went back in and set it to 13ah. done
Then tried "BRA". success.
Seril number failed but then I tried to match the number of digits by adding 4 zeros. 0000XXXXXX worked!
Drives perfectly. My ghetto install tho...yikes.
__________________
Old 08-18-2019, 11:15 PM   #24
madface
Member
Drives: Golf R
Are you guys not going through batteries every 12-16 months? Iíd have a hard time justifying saving a few pounds over spending a couple hundred dollars on a battery every year.
madface is offline   Reply With Quote
Old 08-19-2019, 01:13 AM   #25
axthomson
Senior Member
Drives: 2019 Golf R, 2014 CRV
Braille has a 10 year warranty. I’ve also had mine for 3 years with 0 issues in a Cayman and now my 19 R
__________________
axthomson is offline   Reply With Quote
Old 08-19-2019, 03:23 PM   #26
Diggs24
Senior Member
Diggs24's Avatar
Thumbs up
Drove it to work today. All good.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
