GESI (probably) won't pop a CEL and regular probably will without a spacer, but both should help avoid smell and terrible emissions.
Thanks!
Anyone have possible solutions I could do to fix a loose clamp between the midpipe and stock catback? When I first installed it, I noticed the midpipe was 1-2 mm wider than the catback so the stock clamp wasn't very tight on the catback side. I had to go to a shop to get them to tighten it. Since then it has gotten loose again. I was thinking about buying a more flexible clamp. Any suggestions you guys might have will be much appreciated.
The last time my buddy helped me tighten this, he said that it may be a good idea to look into one of these for a more permanent fix. My other buddy is a welder that supposedly could get this done pretty easily. Does this sound feasible/correct?
https://www.amazon.com/Interlocking-Flange-Stainless-Exhaust-Clamps/dp/B0042C1WA4
