FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Cosmetic Mods (interior & exterior modifications)
Reply
Thread Tools Display Modes
Old 07-14-2019, 06:20 AM   #1
anotero
Senior Member
anotero's Avatar
Drives: Mk7 GTI S DSG
Gas Pedal Spacer - Upper
Had anyone tried installing a spacer than raises the accelerator pedal cover? Does anyone make those?
anotero is offline   Reply With Quote
Old Today, 07:07 PM   #2
Mike-E
Senior Member
Drives: 2016 Golf-R
I made my own using the thickness I needed, plywood. Then I used a hole saw to drill it full of holes (reduce weight). After I painted/installed it, you can't tell it is not OME.
Before, I had a hard time heal/toeing because the brake was an inch or more above the gas pedal. Now, it is easy-peasy.
Mike-E is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
