JasGTI
- Woodbridge CT
What's the max psi I can safely use on eurodyne adjustable?
APR has an interesting system to dynamically adjust the max boost you can run actually. Every cross post, redundant thread, and/or testy reply you make here is detected by a deep learning neural network which sends a command via cellular radio to a GSM chip in the car to lower your boost limit by 1psi.
I doubt you need to worry about excessive pressure.
