I started thinking fiberglass enclosure. Then I went to a flat MDF box (bought the driver at that point). Finally ended up with a 5 Gallon bucket & panel.
PLUS
-Light
-Cheap
-Easy to build
-Works great
-Tough cargo floor
MINUS
-Requires careful design
-Bucket could crack apart over time (not tough to replace tho)
-Won't stay up with just OEM tabs
So the materials are:
-Cabinet grade plywood
-5 Gallon "food-safe" bucket
-Dayton shallow mount 10" sub
-Screws, spray glue, threaded inserts, paint, rubber grommet
-Scrap stair tread (1" thick hardwood ply)
-Scrap 1/2" plywood
-PA Speaker handle
The driver is fine but I would get a conventional one if I had planned this from the start- thought my shallow MDF box would require it. The outer flange was just touch too large- clearance was tight with bucket.
Rejected fiberglass because I hate working with it. The MDF box was going to be silly heavy with proper bracing. Then it occurred to me that since I use the cargo area like a pickup (do a lot of DIY stuff), I could kill 2 birds with one project: Tough cargo floor AND a decent sub. Then I considered all manner of containers for the lower enclosure- most of which would vibrate like hell at even modest volume.
Cylindrical shapes are inherently strong under pressure (see air tanks), except for the ends, if flat (see air tanks with dome bottom). Food-safe type 5-gallon buckets are fairly strong and dirt cheap. If I could design a means to reinforce the ends, it should work well.
So the stock cargo panel is used as a cutting template for a high-grade 3/4" plywood (Home Depot) replacement. This panel is then the top cap of the enclosure, and quite strong. The ideal volume for a sealed enclosure for this driver, at the average diameter of the bucket (it tapers a bit of course) came damn close to exactly the bucket height needed to reach the floor pan. Building-up the height of the bucket with a spacer beneath, one that could be trimmed down to just the right thickness, would leave about half the weight of the unit carried through the bucket, and ¼ on each left/right hanging sill. This would put the bucket bottom, the surface most likely to become a resonator, in (hopefully) sufficient compression to keep it quiet. That was the plan, anyway.
After cutting-out the new panel, next step was to bore a series of holes to balance the open area for the sound to pass through with enough material for strength. I went with a gut estimate of about 1/2 bored. Drew a simple grid and used a forstner bit with backing scrap for clean holes. Easy peazy. Then installed the threaded inserts that will hold the driver from the top. Eased all the edges with a mini router.
More to come...
PLUS
-Light
-Cheap
-Easy to build
-Works great
-Tough cargo floor
MINUS
-Scrap 1/2" plywood
-PA Speaker handle
More to come...
