I found this video but it doesn’t show much
https://youtu.be/9ZAEA5zjfrA
Dave, do you have any more pictures on how to add the wire to the abs connector? Do you have to do everything with small pliers through the back of the bulk head on the connector?
Thats right, its a BOSCH unit. I looked at the pins on the ABS Side, all the 38 Pins are populated. ..
What's the part # on your ABS controller?
My NAR 2017 GSW 1.8 TSI has ABS controller (J104) 5Q0614517AF, made by Bosch
The Erwin Manual for my car shows a 46 pin connector. Have not verified this in person. Interested in doing this mod.
Yep that the exact same ABS module on my vehicle as well., my part number is - ABS Controller (5Q0 614 517 AF), which is a 38 Pin version. the manual from ELSAWIN publishes the diagram both for 38 and 46 Pin versions.
Hello, I tried this retrofit, I plugged as shown and unfortunately the button does not activate anything, I said that I equipped my car with a real TPMS system with the pressure in each wheel live on the discover
I know that with the tpms we can not perform SET, me what I want it is just displayed the menu when I press the button only that, you think it's possible to do that?
