Gravy Jones
- Chattanooga TN
I'm considering installing springs using the 2x4 method.
Has anyone seen/tried this before:
http://forums.vwvortex.com/showthre...ings-DIY&p=110921153&viewfull=1#post110921153
This seems like a good way to help get the strut out...
The strap is actually a pretty good idea. But probably not necessary. I used the bolt on 2x4 method to install my pro kits, no straps, and was able to do the job alone in my driveway in about 5 hours. Zero issues then or since. I’d you use a proper strut spreader, you probably won’t get much benefit from the strap. The knuckle should drop off the strut almost by its own weight.
