My 2015 gti is coming up on 50k and was wondering if any of you have done a brake fluid flush. Is it necessary for the longevity of the car? Will I have any bad side effects if I don’t change it, beside a mushy brake pedal?
Thanks
In several hundred thousand miles of driving over 38 years, I have only changed brake fluid when changing brake pads and rotors. After 50k miles, you're probably due to at least check if you need a brake job. If so, it's a good time to bleed out all the old fluid and put in new.
But if your brakes are working fine and you don't already have a mushy pedal, you can easily wait until you do a brake job. It's not something you have to do just to do it because you're worried. Changing fluid when it's not necessary is nothing but a waste of money. It won't affect longevity of the car or cause any problems.
While brake fluid is hygroscopic (absorbs water over time) if it's not causing issues, there's no reason to change it.
And for the record, I have generally had to do brake jobs around the 40k - 50k mark.
Now of course if you're having a mushy pedal then the fluid has already started to disintegrate and it would be a good idea to change it.
Thanks
Thanks guys for all your advice, my brakes still have about 50% life on them as it’s just my DD and doesn’t get driven real hard, but I’m still gonna do the flush probably, because VW recommends it. Do you think this would be a good bleeder? It doesn’t have the catch bottles, but I figured I would just put drain pan down or something.
https://www.ecstuning.com/b-motive-...hL240whiInFW1C2SkdTlLeYWnrwS9NSxoCxIYQAvD_BwE
^gwt the one from shopDAP. it includes the drain bottle
As far as ehat everyone is saying, this is often an over looked service. Brake fluid is meant to carry dirt and other crap that may get into the lines. It also picks up water. I would highly recommend following the intervals for it, which is 30k.
Ya I'm in the process of doing this, I'm using motul rbf660I really don't understand why this is a service people want to ignore.
A liter of synthetic brake fluid is what, $10?
If you have a compressor, a cheap vacuum bleeder is like $30 on Amazon. A full sized fluid extractor with adapter for brakes can be had for like $80 if you shop around, and has a ton of uses.
So for a total of $40 and 20 minutes work during a tire rotation or other brake service, you're all set and you will prevent rust and corrosion inside the brake system from the hygroscopic properties of brake fluid.
You do not need VCDS or OBD11 to cycle the ABS system unless you introduce air into the system.
Vacuum the res, refill with clean fluid, and then just go caliper to caliper with the vacuum bleeder. Have someone else pour fluid in while you vacuum it out. Or just do it yourself but be careful not to go too long without refilling the reservoir so you don't suck air.
Very easy and simple.
Bad advice.
