KevinC
- '19 Golf R, '21 M2c
I got the car back this afternoon. Here's the writeup:
VEHICLE DOES NOT ROLL TOWED IN TECH CONF CONCERN
NO FAULTS RE DRIVETRAIN STORED IN DTC TECH FOUND
LEFT REAR AXLE HAS TORN CV BOOT & INNER JOINT.
TECH REMOVED LEFT REAR AXLE & FOUND AXLE INNERQ
JOINT SEIZED. ROTATED RIGHT REAR WHEEL TO VERIFY
AXLE OK. HEARD METAL GRINDING NOISE AT REAR DIFF.
TECH CHECKED HALDEX FLUID, FOUND FLUID LOW. TECH
CHECKED REAR AXLE OIL, FOUND AXLE COMPLETELY DRY/
EMPTY. TECH FOUND HALDEX SEVERELY DAMAGED
INTERNALLY. TECH REPLACED LEFT REAR AXLE, BOLTS &
DIFFERENTIAL ASSY, FILLED BOTH HALDEX AND AXLE TO
PROPER FLUID LEVEL AND COMPLETED FOUR WHEEL
ALIGNMENT WITH ACC. TEST DROVE SEVERAL MILES TO
VERIFY THAT VEHICLE DRIVES STRAIGHT AND TO VERIFY
REPAIRS, CONFIRM NO ISSUES WITH REAR DIFFERENTIAL
AT THIS TIME
NOTE: DIFFERENTIAL SUPPLIED BY XXXXX VOLKSWAGEN ("Dealer A")
Total on this invoice - $1601.81, but that doesn't include the new diff, which was supplied by the dealer that made the mistake in the first place - no idea what that thing cost.
The car seems fine, with one minor annoyance - my steering wheel is now a few degrees off-center, and it was perfectly centered before the alignment job. So now I either have to put up with it, or drive all the way back (160 mile round trip) to get dealt with. Alignment seems spot-on. Otherwise, the car is its old self again. I'll decide by Monday if I want to have the steering wheel tinkered with, or just live with it. For now, just happy to have her back again after 20 days.
AT THIS TIME
