anotero
- Hither and thither
- Mk7 GTI
Can anyone tell me what those are for? They are not part of the brake lights. I am not sure what they are for.
They can be coded to work. Mine function as brake and turn signals
Correct, US spec they are coded off from the factory
Do you know what they are used for in other countries? That is if they are not coded off in those countries. Just curious.
What do you mean by inboard taillights? Do you mean the ones on the hatch? If so, those contain running lights and the reverse lights. When your headlights are on, they are also on in the US.
There is a bulb closest to the car centerline, next to the inner L light. It does not come on.
I don't think there is actually a bulb in that location. The bulb holder has the hole blocked off. That's for the rear fog, I think. European requirement for the driver's side of the vehicle (It's on the right side in the UK, left elsewhere).
This. In US cars, both sides look the same - they're molded plastic, without bulbs or bulb holders (even though it may look like there are bulbs there). You'd have to replace the whole housing and add in wiring to the BCM (or a harness) and code to work.
Wow. Not saying I absolutely need those rear fogs, but it seems like NA GTIs are getting the short end of the stick.
They always do.
They always do.
What do you think the main reason is? Regulations?
