terp_man
The wheels came from VMR with the conical lugs?
If you bought them used, that could be the problem here...the previous owner may have used the wrong lugs and therefore damaged the wheels, because they're typically ball seat with VMR's
But, as already said, you'd want a 27mm-30mm length wheel lock
Thank you. Yes this is exactly the case. The previous owner used conical lugs. I'm going to have them replaced this morning with my stock ball seats.
Also I appreciate you answering the actual question I was asking instead of trying to mansplain or bash a square peg into a round hole.
