tonyg109
- Eastern Shore, MD
I noticed a break fluid leak right as my wife was going into labor with our kids. Turns out it was normal.
Yeah, I got it even if no one else did!
Well considering I've never had a DSG, no I didn't notice. Not sure why the smart ass remark was necessary but you do you.
Yeah, I am keeping an eye on brake fluid level. It is probably at 90% or so. I was told DSG fluid stinks badly, and this stuff does not and does not look like motor oil, coolant or washer fluid (that would just evaporate). I smelled brake fluid reservoir cap and it seems the same.
Just trying to understand what exactly can leak fluid under normal conditions. reservoir cap? Is this stuff under such pressure that it can leak through the cap rubber seal? Would I see some residue than or brake fluid is super thin?
It can be forced out of the cap if there is pressure, but that usually only happens if overfilled. Usually it will be clear that the reservoir has had leakage. Dirt will stick to the leaking brake fluid.
Is your brake fluid clear? If so, that's def DSG fluid. There is an O-Ring on the DSG filter housing (just like the oil filter housing). Chances are it's as simple as that.
Replace $2 O-Ring, torque to spec, done.
If you didn't bother to read the thread before posting than you shouldn't have posted. That's what I was getting at.
Hoon pretty much answered all your questions. But to add, if it is brake fluid, put your finger in it and then pour some water on it. Brake fluid is... hydroscopic? phobic? can't remember, but it washes away with water, where oil won't.
Unlike the tech's have told you, DSG fluid can be clear and looks exactly like motor oil. The smell is not bad, when compared to certain other trans fluids. Brake fluid pretty much has no smell though. I smelled a bottle of DSG fluid, and depending on your olfactory senses, it may smell slightly sweet.
If it is brake fluid leaking you will see wetness around the reservoir, master cylinder, and brake lines. If you have driven enough mileage with something leaking, often dirt will accumulate in the area.
Where did you get the brake fluid?I dipped left finger into the puddle and right finger into brake fluid than washed with cold water. Brake fluid washed right away where oil from the puddle did not and remained on my fingers (thin film). I smelled them again. Brake fluid has light aromatic smell, where leaked oil has nothing (at least to my nose).
This is very good tip and I appreciate it
Sigh.... Did you clean the top? How long was the top off?I took a sample from reservoir
Left the car at dealership. Mechanic still claims it is a brake fluid, he submerged fluid in the water to test it somehow. I allowed them to drive it to show that it is not from reservoir. Will see what they say.
Horsemanure.Have more details. I was told that leaked oil dissolves in water so they believe it is brake fluid that might be from master cylinder due to heat from spirited driving. I am going to guess that I am more spirited than you guys
