Old 08-05-2018, 02:15 AM   #1
bsspencer42
Drives: 2017 GTI Sport
Missing Transmission Fluid Fill Hole 2017 GTI Sport
I am wrapping up an RSR clutch install and I am trying to fill back what tranny oil leaked out when taking yet out for the swap but to my surprise the fill hole/plug is not in the design of my transmission. I have seen videos and photos online and I know exactly where it should be but it isnít there!
How can I go about topping off my transmission fluid with no fill hole and no idea how much fluid I need to put in?
bsspencer42 is offline   Reply With Quote
Old 08-05-2018, 02:42 AM   #2
Well shit lol
If you have the car lifted level (all four corners) you could fill it via the drivers side axle cup
Maybe measure first but IIRC that’s the same level
Old 10-06-2018, 05:32 PM   #3
Huntermike
Drives: 17 GTI SE 6M PP LP
My car is the same....I guess it really is a lifetime fluid.
Huntermike is offline   Reply With Quote
Old 10-06-2018, 05:36 PM   #4
“Lifetime” is through the end of the warranty
I changed mine at 36k and it was cooked already
Old 10-08-2018, 07:33 PM   #5
TrinivdubOG
Drives: MK7 R, MKIV GTI, MKIII VR6
why would fluid leak out during a clutch change? Don't recall having this problem when i did mine.
TrinivdubOG is offline   Reply With Quote
Old 10-08-2018, 09:18 PM   #6
SugarMouth
SugarMouth's Avatar
Drives: 2016 GTI Autobahn DSG PP LP
Answer from Jack Watts: You have to add fluid through the selector bolt, which is above the reverse sensor switch. It's plastic, 19 mm. Remove the air box and put the car in neutral, then remove the bolt.
2016 GTI Autobahn DSG | FBO | Littco L450
SugarMouth is offline   Reply With Quote
Old 10-09-2018, 01:15 AM   #7
Huntermike
How do you confirm the correct fluid level?
Old 10-09-2018, 01:32 AM   #8
SugarMouth
SugarMouth's Avatar
Second half of his post:
"Problem is, there is no way to set the level besides draining, then refilling 2.3 liters, so if you don't know how much leaked out, you'll have to drain and fill.This is straight out of the factory service manual..."
I would just measure what came out and add that amount back in.
Old 10-09-2018, 01:37 AM   #9
That’s not accurate. It’s fill to spill out the port on the side that he’s lacking...
That’s why he needs to check what I said right off the get go. Is the missing fill port at the same level as the axle cup? If so, fill to spill there and call it a day.
From empty it takes 2.3 liters to reach the full or point that it spills out (as long as the car is level)
EDIT: after reading the above that’s much easier if the axles are already back in
Old 10-09-2018, 05:40 AM   #10
GTIManEG
GTIManEG's Avatar
Drives: 2015 GTI 6MT
Originally Posted by Gti jake View Post
Thatís not accurate. Itís fill to spill
Not all VW transmissions are "fill to spill" some in the past, 5speeds and 6speeds are fill through the selector bolt.
From my years of working on VW/Audi, It seems to be based on the manufacture of the casing.
What SugarMouth said is correct for this year of car.
IS38 Maestro | FBO | Fast AF |
DynoJet Stage 2 HT
DynoJet Maestro IS38 W/M
GTIManEG is offline   Reply With Quote
Old 10-09-2018, 07:17 PM   #11
roystr
Drives: Always VW
Man, VW...what a stupid move to save a few cents!
2018 Tornado Red SE DSG
Unitronic: Stage 2 ECU / Stage 2 DSG / DP
VWR Springs / Neuspeed RSE-10
roystr is offline   Reply With Quote
Old 10-09-2018, 07:57 PM   #12
MK717
MK717's Avatar
Drives: '17 GTI Sport
Went through this with my clutch install. Didn't realize it was lifetime and figured i'd change fluid while doing the clutch. It wasn't until after draining the fluid and doing the clutch that we realized there was no fill hole. We filled 2.3 through the selector bolt. I haven't had any issues going on about 3 months.
2017 Pure White GTI Sport 6MT | Tomioka IHX475 | DKM Stage 3 Twin Disc Clutch | BC Racing BR Series Coilovers | Eurodyne Stg 2 (Moose Tuned) | Magic (ebay) Intercooler | MAPerformance Catted Downpipe | Vibrant 17950 Resonator | Magnaflow Catback
MK717 is offline   Reply With Quote
Old 10-09-2018, 10:06 PM   #13
TrinivdubOG
still don't understand why you would remove the axle cups to take out the gearbox, seems like the much harder way to go around it...either way hope you got your answers above.
Old 10-10-2018, 06:33 PM   #14
ErBall
ErBall's Avatar
Drives: A3 MQB
Removing the passenger side axle cup makes it quite a bit easier to drop the trans. No need to rotate the trans to 'walk' the axle cut around the top of the flywheel.
A3 - ED STG2/DSG - BB DP - EBM IC - BFI Mounts - Fluidampr - BC BR/Swift
ErBall is offline   Reply With Quote
Old 10-10-2018, 07:44 PM   #15
TrinivdubOG
hmm makes sense, however i just dropped my entire subframe when i did mine. I figured a couple bolts extra vs messing with those cups was worth it.
Old 10-10-2018, 08:20 PM   #16
russiankid
Drives: Das Auto
Don't you have to undo the steering rack, control arms and sway bar to get the subframe to drop? With the axle cups, its one bolt per cup and they come out without any effort.
russiankid is offline   Reply With Quote
Old 10-10-2018, 08:53 PM   #17
TrinivdubOG
LOL yes to all, but bad experiences with my mk4 and persistent leaks after, didn't want to take the chance with the R... Besides I did it on a lift so it wasn't that hard. Hardest part was supporting the subframe with my head
clutch, fill plug, fluid change, transmission, transmission fluid change
