Old 08-20-2017, 06:09 AM   #137
rjtrout
Drives: 2016 VW GTI
Originally Posted by Oldschoolmk7 View Post
Yeah Baby! Been waiting for this... Make sure you slam throttle wide open at 55 mph in 6th. Keep doing that 8-10x to check for slip. Lol.
Haha
Sent from my XT1575 using Tapatalk
rjtrout is offline   Reply With Quote
Old 08-20-2017, 06:40 AM   #138
0bLiViOuS
Drives: 2016 GTI SE PP 6MT
Turbo went on today so I'll keep everyone posted if it starts to slip
2016 GTI SE 6MT
IS38, ED Maestro, CTS DP, IE Intercooler, IE Closed Air Intake, CTS TIP, Neuspeed Charge Pipe/TMD
1995 Mitsubishi 3000GT VR4
1991 Honda's CRX HF
0bLiViOuS is offline   Reply With Quote
Old 08-20-2017, 12:34 PM   #139
Oldschoolmk7
Oldschoolmk7's Avatar
Drives: Mk7 GTI
Question
What do you think of upgrade so far? How was the swap time wise etc.?
2016 GTI S 2 door, stage .5, gonzo
2018 Mustang GT, 10r80, pp, Unleashed tuning 93P, E85, Procharger D1-X and stuff... .
Old 08-21-2017, 12:02 AM   #140
0bLiViOuS
I did a 10psi light pull today and it was much more linear. My IS20 always seemed off or on and didn't feel much power until you got above 10psi it felt like. I was planning on writing a post once I've had some proper time to get on it, I'm just trying to be gentle and check for leaks for a couple days
As for install, it took 10 hours. I could probably do it in 6 or less again. I took my time and figuring out how to remove all the oil/coolant lines was tricky. I only removed the oil feed from the block and the rest from the turbo (took the feed line off entirely first). Mk7gti has youtube videos on it which definitely helped prepare and I called him a couple times I ran into issues (aforementioned lines and something else I don't remember). It really is an easy swap though.
2016 GTI SE 6MT
1991 Honda's CRX HF
Old 08-21-2017, 01:25 PM   #141
Oldschoolmk7
Drives: Mk7 GTI
Good stuff and thanks for update. Start a new thread and keep us posted!
Interesting you say not feeling your old turbo much below 10 psi. I feel mine pretty good right around 3 plus psi. In fact, regular driving I rarely need to go over 2-4 psi. If not in a hurry my car can accelerate at at light throttle and zero boost actually. But, at wot it does ramp up quickly.
I'm sure once over 4000 rpms the difference is night and day though. .
clutch, jb1, slip, tune
