PowerDemon
- Richmond, VA
- Golf GTI, Camaro ZL1
You run the stock clutch on that? Wow. I would have thought you had some issues with it by this point. Also great driving!
I’m still on stock power.
I didn’t open the system either when installing the ti shields and had a terrible pedal.
It doesn’t make sense. What I did should not have created the long pedal issue. The system was bled twice afterwards, the pedal improved but it’s still not 100%.
That’s why I’m thinking of bleeding the ABS pump.
learning how to do this..
https://youtu.be/7Jph334Hv54
not sure why the info is not on the screen.
if you are prudish. you might skip the last min or two.
beers
There's going off and there's going OFF. That was a nice clean "catch". Could have easily spun with the wrong inputs there. Nice job!
