eljay1
- Ottawa, Canada
For winter tires, I'm eyeing a set of after-market rims that are almost OEM spec (rim width, bore size, bolt pattern). The only difference is the offset: OEM is 49; these rims are 42. The calculator at wheel-size.com tells all's good with the wheels except for scrub radius:
Any input / advice is appreciated.
Does anyone know what VW specs / recommendations are, and is a 7mm change in scrub radius something I should be concerned about?Positive scrub radius (about 7 mm). Scrub radius will be changed by 7 mm, this may affect the car's handling. Please check manufacturer recommendations. ...
