Did anyone who's already installed put in a new rear main seal, specifically the iABED one? How about people who haven't yet installed, have you purchased one to put in at the time of clutch install? I'm mulling over just replacing mine while this is apart so it's done. Would be my luck to not replace it and have the OEM start leaking then end up paying double labor. Thanks
I replaced mine when I did my clutchDid anyone who's already installed put in a new rear main seal, specifically the iABED one? How about people who haven't yet installed, have you purchased one to put in at the time of clutch install? I'm mulling over just replacing mine while this is apart so it's done. Would be my luck to not replace it and have the OEM start leaking then end up paying double labor. Thanks
I'm sorry, but you got raped for more than just the stretch bolts. That is over $1000 more than my current price for clutch + labour.
dont make the same mistake as i did, i replaced the RMS with new stock one and it started leaking. Had to drop the trans again and this time i used the iabed one. No leaks so far...
Just received an email from BMP because I'd sent one monday to see if the timeline was still on for end of month. They apparently just arrived today! Long wait is finally almost over.
Trans mount bolts x3, dog bone bolts x3, nuts under the a arm x6, there is a bolt kit you can get, for transmission removal. Might want transmission fluid, I drained mine when I did my clutch to make it a little lighter to lift in and out.Speaking with BMP today, clutch is confirmed to be shipping out! Beginner question but since this is the first time doing this(although having a shop install for me) what hardware/fluids should I be planning to replace?
Edit: here is the kit
https://www.hstuning.com/product_info.php?cPath=15_18&products_id=5599
Sent from my SM-G950U1 using Tapatalk
Picked this up. There is PP and a non PP kit. Not sure the difference but I have a sport so I got the PP kit.
Sent from my LG-H871 using Tapatalk
