beaumier2006
- Santa Cruz, CA
You either left an abs sensor unplugged or you damaged them in some way during the swap. The ABS/Brake light(s) should go away within a couple hundred feet of driving the car, if you disconnected the battery. You shouldn't have to re-code anything.
Unfortunately not the case. I replaced both sensors twice. Nothing is unplugged. Myself and 2 different shops can’t figure it out. The only thing it might be is that the bearing on the A3 is much larger. I saw something about 85mm on some A3 models somewhere. If it is in fact larger then the computer isn’t going to calculate correctly. There for, needing to recode.
Regardless, I bought a different kit and am going to remove this whole setup. I’ll be selling it with a whopping 300 miles on it.
18z calipers
345mm rotors, drilled
Stainless lines for use on MKVII
Red stuff pads
MKVI buckles
MKVI bearings
MKVI sensors
All hardware needed to plug and play
