The video is OK but it may make things more confusing than necessary. It's also worth noting that the 0W-20 oil that tested fine after track use was Redline oil which is considered to be a high quality group V base stock fully synthetic oil. So it potentially might endure more thermal stress without issue than some other synthetic oils. It's likely that he chose the Redline oil hoping that it would give him the best protection under the high oil temps during track conditions. He also completely skipped over required oil specs such as VW 502. Using the correct spec oil can be as important if not more important than oil viscosity.
Seeing as though VW mandates 5W-30/40 oils for most applications there isn't any reason to be using other viscosities oils for 99% of VW customers. If you live in Alaska or some place where the high temp for the day is typically 32 F or lower for months then maybe a 0W-30/40 might offer a minute advantage. If you live where the high temps are typically 90 F plus eight months a year then a 5w-40 might offer a minute advantage. If you track your car then the 5w-40 would offer a small advantage. If your track temps exceed 265 F you need an additional oil cooler.
If your VW calls for 0W-20 then that is what you should use as the engine clearances are designed around that viscosity oil. The jury is still out on what changes if any are advisable for those vehicles that are tracked with an oil requirement of 0W-20. Maybe a 5W-30 VW 502 oil is acceptable? Without actual testing and disassembling the engine for inspection it's going to be difficult to determine the optimal track oil viscosity for these engines.
