0bLiViOuS
- Orange County
Don't worry, we're going to meet up once my clutch is working and I'll make sure he misses the power of the GTI Going to run with the OTS IS38 Maestro file and a custom tune to compare
Yeah, but that sound.....
Ok - once again I have a Maestro FNG question. Wanting to set launch control. Everyone keeps saying you need to flash the new loader file, then load stage 3 DSG, then load tune file.
1. Is the "Loader file" the adjustable tune file (in my case it's my code_002.efu or something like that)found when choosing to download and update my ECU in the flasher?
2. How long has the loader file for the new stage 3 DSG tune been out? I just got Maestro 2 weeks ago, and my last loaded file is the same as what is now available. Or do I need to request the current loader file?
3. In my tune, I set it to 2, fuel cut. I tried the process above to set launch rpm, but didn't work. I had it in park. Should it be neutral?
I'm a fool in search of wisdom....
go into park not neutral if you dsgSetting LC:
- Pull handbrake
- Vehicle neutral
- Rev engine to desired RPM
- Tap brake
- CEL should blink twice, LC RPM is now set. (you can change it later using the same method)
To launch:
- Shut of traction control completely
- Ebrake off
- Press in clutch
- Rev to set LC limit
- Slay V8's
so first off you don’t need the stg3 to activate the new LC. i am stg2 dsg and it works.
you have to do the loader file which will take awhile. i cant answer questions on those files because i don’t remember what i did and i am shit with computers
going into neutral is for manual cars. dsg requires you going into park
The stage 3 gets rid of launch control in the TCU tune. If you are stage 2 TCU you won't be able to launch higher than the stage 2 TCU tune RPM limit.
Oh man I wish I had my gti on slicks to try this. I bet with my luck I would snap both axles
