FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 08-12-2018, 05:17 PM   #1
EmmKay11945
Member
Drives: 2016 GTI
Dsg service.
Does dsg fluid need to be changed exactly at 40k, or can it go a little over?
EmmKay11945 is offline   Reply With Quote
Old 08-12-2018, 05:25 PM   #2
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Quote:
Define a little? 500 miles? Sure. 5k? Probably not ideal.
__________________
ED Moose E50 tune / ED DSG tune / Tomioka IHX475 Turbo / IE Intercooler / MAP cat+res Downpipe / Autotech HPFP / Precision Raceworks 450 LPFP
Diggs24 is offline   Reply With Quote
Old 08-12-2018, 05:49 PM   #3
EmmKay11945
Member
Drives: 2016 GTI
Quote:
Ok thanks
Old 08-12-2018, 06:08 PM   #4
SugarMouth
Senior Member
SugarMouth's Avatar
Drives: 2016 GTI Autobahn DSG PP LP
Heck I did it at 32k, vehicles love fresh fluid.
__________________
SugarMouth is offline   Reply With Quote
Old 08-12-2018, 06:17 PM   #5
Hoon
Senior Member
Hoon's Avatar
Drives: '17 GTI Sport DSG
Did mine at 34k and it looked really good. Mostly stage 2 and 6K miles IS38. Couple days at the drag strip, tons of street pulls. I'm sure I could have gone to 40k or slightly over with no issues.
Other people do them at 40k and the fluid is black and looks burnt, even on less modded cars with likely less WOT time.
I think a big factor is whether or not you have bumper to bumper traffic on your commute.
Regardless, If you just drain and fill it's not that bad of a procedure, should be about $125 and 2 hours time with basic tools and mechanical ability.
__________________
FBO / IS38 / Stratified
Hoon is offline   Reply With Quote
Old 08-12-2018, 06:30 PM   #6
Brinker
Senior Member
Drives: 2015 MK7 GTI CSM 2 DR
Quick question, does US cars have a different maintenance schedule than cdn cars? Reason why I ask cuz my owners manual says to change DSG fluid and filter at 60000 km which works out to roughly 37200 miles, not the 40K that people are changing the fluid at
Brinker is offline   Reply With Quote
Old 08-12-2018, 07:56 PM   #7
EmmKay11945
Member
Drives: 2016 GTI
Yes I had planned on draining it and measuring what came out, then replacing through filter house.
Old 08-12-2018, 08:07 PM   #8
SugarMouth
Senior Member
SugarMouth's Avatar
Quote:
I think this proves a few thousand miles either way won't matter. They are doing that for round numbers.
__________________
Old 08-12-2018, 09:51 PM   #9
16gtiguy
Senior Member
Drives: 16 GTI Autobahn DCC LP, 15 Tiguan R-line
I think type of driving had a lot to do with it as stated earlier. I have an hour commute mostly in heavy traffic. I changed my fluid at 22k miles and it was black, so I plan on doing it every 20k based on my driving style, commute and tune.
16gtiguy is offline   Reply With Quote
Old 08-13-2018, 02:40 AM   #10
EmmKay11945
Member
Drives: 2016 GTI
Is measuring & pouring back in what comes out a good method, or it makes since that there should be a set specific amount that should be put in? And do I need to run through the gears with my foot on the brake, or is that only for the bottom fill method? If anyone knows
Old 08-13-2018, 03:03 AM   #11
Diggs24
Senior Member
Diggs24's Avatar
Depends on how anal you are and if you think they filled it at the factory the right amount.
__________________
Old 08-13-2018, 03:08 AM   #12
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
I would go it as close to 40K as possible if you change it at the specified intervals and need it to keep your warranty in effect.
If you're tuned you might want to change it sooner. If you're at 4 years it might be a good idea to also change the battery,
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Old 08-13-2018, 07:16 AM   #13
George Ab
Senior Member
Drives: GTI MK7, BMW E90
Yes, and no. You measure primarily to determine if your transmission is leaking or was overfilled. You have to be absolutely level to get all the oil out, else you will retain a tenth or two of oil. You should get 4.5 liters (+/- 0.2 L) drained out. Add 4.6L with new filter. I lift the front end to access drain (put on ramps), place my iphone level ap on roof and jack up rear until it reads 0. You can put level flush on bottom of transmission oil pan and check again.
No you do not need to run through gears or get to specified temperature as you are not letting extra oil spill over plastic snorkel by using the overflow factory method. Good picture seen here at bottom of page that shows what is going on with overflow method. https://www.myturbodiesel.com/wiki/d...nic-oil-flush/
George Ab is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
