Thanks Man! Not everywhere has them. Ordered them over the last couple weeks.
Originally ordered rears from THMotorsports as they were listed in stock, cancelled later due to no stock. ECS Had the rears in stock.
Fronts I bought on eBay from two different sellers.
My JB4 logs aren't very organized historically, but these are the latest I had running before I ran the 12.7 . Ran the 12.7 on the first run of the day, went downhill from there.
Looking at your logs, those trims are pretty high, as is your FOL @75. Are you getting any rail pressure codes? You have multiple corrections across the cylinders spanning a large RPM range too. You may consider dialing it back some to tune those out. Maybe post the logs in the Map 6 thread and see what the guys (Diggs, Oblivous)think. Have you sent them to George?
I may attempt to piece together a B8 setup also but it’s slim pickings finding new stock.
Yes I got a few sporadic rail pressure codes as I was doing the tuning. I backed off of that tune after those logs, I should have made that clear. Those are just the logs I have saved that were closest to the 12.7 run.
I had one limp-mode event during my runs at the strip. Made a few corrections after, and the car was happy.
I was working with George on this tune, and we were aware of the situation. There were fairly large ambient air temp variations as we were tuning, making it difficult to dial in. The car is stored for winter now. I plan on having the car ECU/TCU tuned in the spring, and will run the JB4 on top of the tune.
I used the 'just keep ordering until you get one' method. Worked OK
You’re on top of it. Good stuff! What flash are you considering in the spring?
Thanks! The wagon drives so well now, I'm very happy with it. IS20 is great on these, I've ridden in an is38 4 motion wagon and it's wild. Maybe somedayYour car looks fantastic! I am a wagon freak so it is nice to see someone else do one up. I am IS20 with ApR tune for 91 octane. Love the Motegis as well, I have had them in three different cars,mother are a great wheel, mine are black with 245 Indy 500. Keep posting!
