IS20 swap P00AF EPC Light limp mode
williamwong
Singapore
Bad news. After I adjusted the rod and put the end back into the wastegate swing arm. The code comes back again. I think I’m doing it wrongly. Shud I be adjusting with key on and looking at the actual values of the lower and upper limit of the actuator? Currently is 3.57V for lower limit.
Diggs24
de plains! de plains!
2015 GTI
It shouldn't come out of the swing gate arm to adjust. Take off the downpipe at the turbo and feel the wastegate. It should be loose and about 1cm of gap at least.
The IS20 is on the left. See how it lays open a bit? That's what you want.
2slowvw
Moderator
VA
2022 Tesla Model 3
This is correct, and also no, you should not be adjusting it with the key on. You need it to be off so the actuator isn't trying to charge it. With it off it should be a little lose like in DIggs pic, once you turn the car on to do the test, the actuator will tighten it up.
kcasner
Car
Do you know if this all applies to the is38 as well?
Blade3562
Earth
None
I had my IS38 and APR tune installed installed last week, I had one random instance of this code and it has not occurred again. It occurred in a low boost high load scenario climbing a hill in PA. Dealer said I might need to adjust the wastegate since the turbo has now seen a few heat cycles. Is this true, or was it just a fluke? A little bit later I had a 14913(P0234) overboost in the same scenario. I have a feeling these are related, but I'm not 100% sure. Add to my confusion the tune is currently in beta so I'm not sure if these are due to the tune or something mechanical lol.
Veedubtee
Arizona
I had this code on my 1.8TSI with an IS38, DP and APR ECU/TCU tune. It happened on an inclined highway on ramp while cruise was on and I was adding speed via the plus key on the steering wheel.
Veedubtee
Arizona
I got the throttle adjusted by my shop. Since then, I have been trying to reproduce this issue with high gear and low boost on an incline. The tune seems very solid.
crxgator
Raleigh, NC
All the MQBs
So I’m having issues with my wastegate (possibly) and dbv2. The voltage is 3.56 but my wgdc is like 2-3% and it won’t reach target boost. What are people doing for bigger turbos?
crxgator
Raleigh, NC
All the MQBs
Came with new. I’m reading so many different ways on doing this it’s frustrating to know what’s right.
The actuator is from an A6
GTI787
Ft. Lauderdale
2016 GTI
Nut could be loose. We also see pretty often the downpipe clamp loosens and spins around blocking the actuator arm lever.
So sorry to bring this back from the dead but my EPC light came on tonight and sure enough it was the DP clamp which was loose and rotated around blocking the actuator arm. Simple 5 minute fix. Thank You so much!!! Love this group!
