Frank Reynolds
- So Cal
While on a road trip about a week ago, some error flashed on my MFD but I was driving and it disappeared quickly. It was not stored in the infotainment area under "car".
Yesterday I scanned it with my VAGCOM but I am wondering just how serious these codes are? One of them seems to be my gas cap, so that is an easy fix. But it seems like a couple could be serious.
I have an appointment to bring it in Friday but I was hoping some of you guys could help me to understand what is going on so I can communicate with the dealer properly and articulately. Thanks!
Sunday,06,August,2017,17:00:09:26867
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
Mileage: 68798km-42749mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU1GM018790 Mileage: 68798km-42749miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124424002F0000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6DFB757675BF3E23-807A
1 Fault Found:
21406 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 66319 km
Date: 2017.07.19
Time: 07:24:16
Engine speed: 1554.75 /min
Normed load value: 0.0 %
Vehicle speed: 34 km/h
Coolant temperature: 105 °C
Intake air temperature: 32 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.003 V
Unlearning counter according OBD: 9
Engine: operating status: PUC
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 1480 s
MAP_MES_SAE: 24 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.262 V
FAC_TPS_1_SAE: 13.281250 %
FUP_H_SAE: 9520.0 kPa
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4903
Revision: 06253104 Serial number: TFK01507160187
Coding: 0014
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_VW37.rod
VCID: 183F20A9E3FB588652-804C
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52205000001352
Coding: 01FA6BA134210974007E020981C32980D62C9000408194B400430050C008
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 4B958FE5E2ADE31E2F-801E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 67099 km
Date: 2017.07.28
Time: 08:39:26
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000000000002
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACManueBHBVW37X 003019
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 4683BED1F9CF1E76F0-8012
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
1 Fault Found:
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 66975 km
Date: 2017.07.27
Time: 16:07:12
Voltage terminal 30: 12.9 V
Outside air temperature: 38.0 °C
Air distribution flap: actual value: 225
Air distribution flap: actual value: 73.5 %
Air distribution flap: specified value: 31
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 86580307151630
Coding: 000018464041804969E44000001407201000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 7AFB1A21FDB7AA96C4-802E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150703 043 0581
Serial number: 150829093803
Coding: 0E4DDD
No fault code found.
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR02SAW1
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 479DB3D5FEC5077E0B-8012
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H11 0021
Serial number: IBH00000000000386WCL
Coding: 30305A
Side Sensor Driver Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 907 15
Component: SideSensor_Df 001 0887
Serial number: 3570000000095294551C
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 3 - Part No SW: ----------- HW: 480 000 307 15
Component: SideSensor_Pf 001 0887
Serial number: 358000000001DC78A41T
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 400 707 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002A31B7E8F4D1FR
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 400 707 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002A31B7E8F14358
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 407 15
Component: FrontSensor_D 001 6149
Serial number: 3550002AB1B7E8F2805L
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 407 15
Component: FrontSensor_P 001 6149
Serial number: 3560002AD1B7E8F3708R
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150718400233
Coding: 0410
Shop #: WSC 66564 385 16448
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 3F8DAB35A6154FBEB3-806A
1 Fault Found:
617752 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 131
Mileage: 65781 km
Date: 2017.07.12
Time: 08:19:19
Ubat 30 Voltage: 13.80 V
Ignition State: On
Terminal 15: 13.00 V
A/D #1: 0.00 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 03BD090AA180CF0502086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2C57EC794763C42606-8078
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2223
Revision: -------- Serial number: 02081510803718
Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 74E73419DFD3DCE69E-8020
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001307980025264
Coding: 31FFFF
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 270615060505SR
Coding: 003E03200000040000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 4385A7C5CAFD2B5ED7-8016
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001838711
Coding: 011000
2 Faults Found:
65588 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 103
Mileage: 65163 km
Date: 2017.07.01
Time: 09:49:55
65799 - Door Warning / Enrty Lighting
B1775 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:04:44
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 3979C52DB831618E8D-806C
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 230615060505CF
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 428BA2C1D5E72256DC-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001767969
Coding: 091000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:14:53
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Serial number:
Coding: 02730000FF00000051220001001808001F0203D40120010002
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CD72C7987E3042646-8038
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES00ENK
1 Fault Found:
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:03:29
Voltage terminal 30: 12.1 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Channel selection for satellite radio: 0
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 137 mA
SDARS_tuner_status_2-Reception quality: weak_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0566
Coding: 02730002C2821A017F1E06000000
ASAM Dataset: EV_OCULowMQB 001003
ROD: EV_OCULowMQB_VW37.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150620200270
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 6BD52F6582ED031E4F-803E
End-------------------------(Elapsed Time: 03:43)--------------------------
www.Ross-Tech.com
Revision: --H13---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 66319 km
Date: 2017.07.19
Time: 07:24:16
T_AST_SAE: 1480 s
MAP_MES_SAE: 24 kPa
Coding: 0014
1 Fault Found:
P1734 00 [002] - -
1 Fault Found:
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 67099 km
Date: 2017.07.28
Time: 08:39:26
Revision: 00001K01
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 66975 km
Date: 2017.07.27
Time: 16:07:12
Coding: 0E4DDD
Occupant Detection:
Coding: 30305A
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 0410
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 131
Mileage: 65781 km
Date: 2017.07.12
Time: 08:19:19
Ignition State: On
A/D #1: 0.00 %
A/D #2: 0.00 %
A/D #3: 0.00 %
Alternator:
Coding: 31FFFF
Coding: 011000
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 103
Mileage: 65163 km
Date: 2017.07.01
Time: 09:49:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:04:44
Coding: 8102
Coding: 091000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:14:53
Serial number:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 253
Mileage: 63307 km
Date: 2017.06.10
Time: 13:03:29
