Fuel economy accuracy
Jdreg
Wondering if there’s a general consensus about how much the computer generated fuel mileage is off. Would it be a consistent 1-2 mpg to high, for example, for most of the cars. Or is inconsistent from one car to another.
Thanks
IWMTom
Thanks
Mine is out by between 10 and 15%, so I corrected it by 13% for a slightly more accurate readout..
The computer can never be accurate, though.
Tsi7
Ontario, Canada
Mine was about 7% optimistic... Adjusted with obdeleven and its pretty close... Usually +/- 0.2 liters per hundred after doing hand calculations... Sometimes it's bang on. All depends on when the pump clicks off too which will effect the accuracy
SRGTD
UK
Agree, it will only give an indication of fuel consumption.
Calculating the fuel consumption manually over the long term will be more accurate, but this method will also be influenced by how much fuel you manage to squeeze in after the pump clicks off, and the indicated volume of fuel dispersed by the pump being accurate. In the UK, pumps should be checked and tested regularly for accuracy, although I dare say they’re not all 100% accurate.
FloridaNative
Central Virginia
I have hand calculated my mileage since day 1 (20k miles) on my 2017 GTI. The computer in mine is off by 2-3 mpg. Around 2 mpg (6%) on mostly highway tanks and around 3 mpg (10%) on mostly commuting tanks.
-Mike
Strange Mud
Small Town CT
Assorted
mine was about about 2-3 MPG off. I adjusted it through OBD11 107 was the number I used. Doing math over my last extended go around it was within .1-.2 mpg off. The OCD in me is happy. I know it really doesn't affect consumption but another excuse to spend the $70. My justification was turning on the factory alarm. All the other stuff is just frosting.
20ls01
Texas
GTI 2016
Its really weird. Most tanks, the computer reads 2-3 mpg higher but its been spot on sometimes.
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
How do you adjust it using OBDeleven?
southpawboston
Somerville, MA
In the US the fuel pumps never trickle more than a few drops after they switch off. They also have to be calibrated and certified at least once a year, IIRC.
imthanick_a
Ohio
Not this thread again
Wrath And Tears
Azusa, CA
17 Sport, 99 E36
Mine is 100% accurate because I've never hand calculated to see how off it is, so there! Take that you hand calculators. :)
Edit: alright you peer pressured me into it. Hand calculation from last tank is about 2 MPG lower so figure 8-10% off. Seems about right.
