Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > MK7 vs......
Old 05-28-2019, 07:55 PM   #1
EmmKay11945
Drives: 2016 GTI
Stage 2 GTI vs HHR ss
What's going to happen with my stage 2 Gti Vs 09 HHR ss 475hp 400tq. Looks like they weigh about the same as a Gti
EmmKay11945 is offline   Reply With Quote
Old 05-28-2019, 08:17 PM   #2
tknj99
Drives: MK7 GTI
I think you'll beat him first with the ugly stick and afterwards with your car
PW | 3M CS Tint | Clutch Stop | Clutch Bleeder Mod | Clutch Spring Removed | Snow Grate Removed | OBDeleven | ST Rear Sway Bar | Modified stock intake grill with AFE Drop-In
tknj99 is offline   Reply With Quote
Old 05-28-2019, 09:34 PM   #3
Niol8r
You'll both race. One will win, one will lose.
That's what will happen.
Sent from my SM-G965W using Tapatalk
Niol8r is offline   Reply With Quote
Old 05-28-2019, 10:03 PM   #4
bluekid99
Drives: 2015 Volkswagen GTI
I raced my buddys cobalt ss about 450whp with my is38 gti and I beat him by about a length or so...he spun more than anything...its gonna be close with the hhr...dont be surprised if you dont win...they can be nasty
2015 GTI SE -IS38 APR, BFI Stage 2 Mounts, Unitronic IC, ECS Throttle and Outlet Pipes, RS7 Plugs, Fluidapmr pulley, Injen Evolution Intake, CTS Turbo Inlet Pipe, Niche Targa M129 18x8, VWR Springs, Unitronic Downpipe, Magnaflow CB, 034 RSB and Endlinks, ECS Pendulum Mount, BoombaRacing Weighted Shift Knob, CTS Short Shifter, BMS Clutch Stop, SB Stage 3 Daily, RS3 Coil Packs
bluekid99 is offline   Reply With Quote
Old 05-28-2019, 10:05 PM   #5
EmmKay11945
Drives: 2016 GTI
I wasn't expecting to win at all since its almost 500 HP 😂
Old 05-28-2019, 10:07 PM   #6
EmmKay11945
Drives: 2016 GTI
That's interesting, never thought about that.
Old 05-29-2019, 07:29 AM   #7
Zx2man
Drives: 2017 Gti sport
Well dial in that adjustable ED file with some e85 and do your best. Let’s us know your mods n settings and result when it’s over. Good luck.
2017 GTI PP DSG NB METALLIC
EuroDyne-CTS downpipe-CTS intercooler -CTS inlet-SB intake-Powerflex dogbone insert
Zx2man is offline   Reply With Quote
Old 05-29-2019, 09:51 PM   #8
vincevtr
Drives: 2017 GTI
i would just bail to eliminate all chances of losing to such an ugly car
Ice pack in the air filter box
vincevtr is offline   Reply With Quote
Old 05-30-2019, 02:53 PM   #9
EmmKay11945
Drives: 2016 GTI
Originally Posted by Zx2man View Post
Well dial in that adjustable ED file with some e85 and do your best. Letís us know your mods n settings and result when itís over. Good luck.
I got some e30 in it. I'll just slide it up to 98 and 24psi
Old 05-30-2019, 02:53 PM   #10
EmmKay11945
Drives: 2016 GTI
I don't have the maestro so
Old 05-30-2019, 03:18 PM   #11
Hoon
Hoon's Avatar
Drives: '17 GTI, Sequoia, Turbo Gixxer
Some of the Ed files have super aggressive high octane timing maps, I would move the slider 1 octane point at a time and datalog.
E30 will not support 98 on the slider depending on the high octane table in your particular base map.
Littco L450 w/ MPI, self tuned via Maestro
Hoon is offline   Reply With Quote
Old 05-30-2019, 03:58 PM   #12
Jose_Gti
Jose_Gti's Avatar
Drives: Golf GTI MK7
Truly ugly indeed...
MT APR stage II APR Down Pipe. APR Intake. RS7 plugs/RS3 Coil Packs. 034 Dogbone. APR short shifter full system. ECS Clutch Bleeder Block. Billy Boat Resonator. TTRS Clutch kit. UBQ unibrace and Neuspeed sway bar. APR Intercooler + Apr boost hoses, apr turbo inlet pipe.
235/40ZR-18 Michelin Pilot Sport A/S3. BMS pedal tuner.
Jose_Gti is offline   Reply With Quote
Old 05-30-2019, 04:09 PM   #13
EmmKay11945
Drives: 2016 GTI
Keep moving it up 1 point until I see knock, then move it back down 1 point?
Old 05-30-2019, 04:20 PM   #14
Hoon
Hoon's Avatar
Yes.
Old 05-30-2019, 08:13 PM   #15
Zx2man
Yes Hoon is correct. Log n adjust, and so on. Then back it down when your start seeing knock. If you go one octane point at a time it’s slower but safer.
The ED adjustable files must have been updated since I last used then about year ago. I could dump 3 gal of e85 and run the 98 setting with no issues. I’ll have to give it a shot again this summer. I’ll start low and work my way up.
Old 05-30-2019, 08:26 PM   #16
randomhobo130
I've always laughed at the thought of an hhr SS. I thought it's performance would be as ugly as it's looks. Guess i need to change that thought process a little based on the replies in this lol
Sent from my Pixel 3 using Tapatalk
randomhobo130 is offline   Reply With Quote
Old 06-01-2019, 01:17 AM   #17
EmmKay11945
Drives: 2016 GTI
Yeah kinda looks like something a molester would drive
