Golfs everyday
- USA
How was the accuracy of the cheap gauges?
Not very good. They were off by 0.5 to near 1.3psi, but they were consistently off repetitively so not entirely useless.
Pen type I previously compared with my good gauge wasn't too bad but with only lines in 2psi increments I can't really measure accurately. I keep the pen type in my car for emergencies only to see if it's off by a big amount when the TPMS light comes on. Plus, it's measuring running temps so only good to compare with other corners of the car. Usually I can feel the car is loosing air from a corner long before the TPMS light comes on though.
What is the need/are the benefits to checking your tire pressure daily?
Also this is probably a dumb question but don’t you lose a little bit of pressure every time you check? So if you check every day you’re more likely to need more air sinner? Just curious...
I think you read my post wrong. I don't measure daily.
